Greetings,
Apologies to begin with, but in order to explain what I'm trying to do I have to use the "L" word-
In Logic if one records audio in a "sequence" and then the audio is set to "flex time" it will be analyzed and match any subsequent tempo changes. That is, if I record quarter note (audio) claps at 90bpm and then change the tempo to 100bpm, the claps will automatically adjust to match the new tempo.
How does one achieve a similar result in DP? I've looked in the manual but can't seem to find it.
Cheers.
Changing tempo of recorded audio
- Shooshie
Re: Changing tempo of recorded audio
In the current manual as of January 2015 (DP8), the sections that deal with audio tempos, beats, and manipulating them, are Chapters 49 and 50, starting respectively on pages 615 and 621.
If you're in a different version, the names of the chapters are "Tempos and Audio," and "Beat Detection Engine."
So obvious I don't know how I missed it. Well, it is a big manual.
Thanks for the tip.
MJ
Thanks for the tip.
MJ
