can't see pitch information in Sequence Editor
edurbrow@sea.plala.or.jp
Post by edurbrow@sea.plala.or.jp »
I can see pitch information in the Waveform Editor, but it does not show up in the Pitch layer in the Sequence Editor. This is inconvenient. I tried closing and reopening, Choosing Pitch several times. Not much I can think of to try. It always worked well before.
I'm on DP7.4.
(Is there a way to send screenshots here?)
Ed Durbrow
Saitama, Japan
Re: can't see pitch information in Sequence Editor
I should mention this is an imported file, a bounce in place from Logic X.
Ed Durbrow
Saitama, Japan
daniel.sneed
Post by daniel.sneed »
Of course, you did select *pitch* over *soundbite* (or *volume*) on the left of the track?
Time to go back to that great DP user manual?
Tritonemusic
Post by Tritonemusic »
daniel.sneed wrote:Of course, you did select *pitch* over *soundbite* (or *volume*) on the left of the track?
It seems like he did that:
daniel.sneed
Shooting in the dark:
in DP preference: *analyse pitch when needed*?
daniel.sneed wrote:Shooting in the dark:
Thanks a lot. That is one I should try.
I finished that particular task, so I'll make a note of it for next time.
I have to say this project was done in Logic, but DP's pitch correction is so much better and elegantly implemented, that even working only in the Waveform Editor it saved time to import it to DP because there was no backtracking because of glitches.
Ed Durbrow
Saitama, Japan
