Using 32 bit plug-in in DP 8.07
- doodles
Guys
If I"m running DP 8.07 in 64-bit mode, is there a way to use my old 32 bit plu-gin (analog factory)?
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
- doodles
Re: Using 32 bit plug-in in DP 8.07
and btw, tried j-bridge. Can't get it to work...
J-Bridge works on VSTs only. 32 Lives works with many AUs.
Many threads on these subjects. Use Advanced Search to find them.
- doodles
cheers mike. I did a search in the bar above, but took me to a million topics not relevant. That's what I found j-bridge through.
But that would explain it if only works with VST.
Will go look for 32 Lives.
Much appreciated!
Much appreciated!
any reason for you not to run in 32 bit mode? If you aren't taking a performance hit, or losing some 64 bit plugs, might be worth considering. I'm doing that on some legacy sessions with no problems, your situation is of course different.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
