Sorry if I'm posting in the wrong place. I've forgotten how to export audio tracks in such a way that fades are included. I know I can bounce each track individually but that seems like a long way round. Grateful for any advice.
Tony
DP 7.24
MacPro (2009
Yosemite
Exporting audio to include fades
Re: Exporting audio to include fades
I'm not sure what the best method is, but if you Merge Soundbites first, the fades will be permanently rendered. Then, you can export.
Thanks - I imagine that works with just a single sound bite (ie with nothing to merge to but just a fade at the end)?
Yes. You can also select multiple soundbites from multiple tracks at the same time and merge all at once.
- daniel.sneed
AFAICR, merging multiple soundbites in a single track, will produce one soundbite including all of them. A new associated soundfile will be created in the process. In other words, Merge is a constructive process.
AFAICR, merging a soundbite with a fade will change your soundbite in that track, for the fade will be *printed* in the new soundbite. But the original associated soundfile will remain as long as you don't clear unused soundbites and delete undo history and files.
dAn Shakin' all over!
