Cloud Storage for DP Projects
Has anybody found cloud storage for DP projects. I'm looking for an online storage site where I can manually copy DP projects and maintain the folder and file structure within the project, just as if I was copying to a backup hard drive. All of the cloud services I've reviewed have restrictions on folders which make them unusable for a DP project. I'm not looking for an automated backup service, just online storage.
DP 10.11
OSX 10.14.6
Mac mini (2018) 3 GHz Intel Core i5, 32GB ram
Mac mini (Late 2012) 2.3 GHz Intel Core i7, 8GB ram
Apogee Symphony I/O
OSX 10.14.6
Apogee Symphony I/O
Re: Cloud Storage for DP Projects
Zip the contents then upload. All will be saved correctly.
Wow! That is so simple. Thank you MIDI Life Crisis.
DP 10.11
OSX 10.14.6
Apogee Symphony I/O
OSX 10.14.6
Apogee Symphony I/O
Simple is my middle name... LOL No problem. It's also the best way to email projects to others, otherwise the files get messed up.
I use OneDrive (formerly Skydrive) and I love the way it works. I often work on a project at one studio and by the time I'm at my home studio the project just created is already downloaded and ready to work on at home. I haven't run into any problems using Logic and DP with OneDrive. I have had problems with DropBox, Cubby, and BitCasa.
Thank you for your reply swpowe. Do you also zip the contents of the DP project before uploading?
DP 10.11
OSX 10.14.6
Apogee Symphony I/O
OSX 10.14.6
Apogee Symphony I/O
- FMiguelez
What MLC suggested, the whole workflow, can be done with the press of one key vía AppleScript or Automator.mmestek wrote:Thank you for your reply swpowe. Do you also zip the contents of the DP project before uploading?
I don't zip or compress partly because I'm not archiving I use OneDrive as part of my normal workflow. I can access my projects from anywhere and always have the most recently saved version (autosave or otherwise). This works even if I have the project open on my studio machine and then start working on my home machine (then I'll do a "save as" to create a new version from home.
There's also Gobbler...
https://www.gobbler.com/announcing-gobbler-2-0/
Great family and friends!
F. Douglas
F. Douglas
Can anyone say "Dropbox?"
I'm slowly migrating from Just Cloud to Drop Box (1TB for $99). I've found that I need to zip my DP Project folders before uploading. It's a manual workflow which is fine for archiving. Just Cloud provides scheduled incremental backups and restores. But beware: their "unlimited" plan actually is capped at around 800gb so if you need more than that look elsewhere.
Frank Ferrucci
http://www.ferruccimusic.com
I use Carbon Copy Cloner to do a daily backup of my current project to my iCloud account. I used Jottacloud before also, and had good results.
12-Core Mac Pro, OS: Sierra w/ DP9 - always the latest version. Love of film music.
Thank you all for your replies. I'm going to experiment with your suggestions.
DP 10.11
OSX 10.14.6
Apogee Symphony I/O
OSX 10.14.6
Apogee Symphony I/O
I tried OneDrive and I'm not able to upload folders. How do you do that?swpowe wrote:I use OneDrive (formerly Skydrive) and I love the way it works. I often work on a project at one studio and by the time I'm at my home studio the project just created is already downloaded and ready to work on at home. I haven't run into any problems using Logic and DP with OneDrive. I have had problems with DropBox, Cubby, and BitCasa.
DP 10.11
OSX 10.14.6
Apogee Symphony I/O
OSX 10.14.6
Apogee Symphony I/O
Try Zipping the folders before uploading
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
