How do you convert tempo changes into one static tempo
- joelmusic
I need to have a MIDI file with lots of tempo changes be converted so the note data _sounds the same_ after converting to a static tempo. I remember a feature in DP where you could convert a file with tempo changes to a static tempo and it would push the notes around in the file to compensate. I need this for a Disklavier sync-to-video project that can't have tempo changes (but I need them to compose!) - any help would be much appreciated.
Mac Studio Max - 32GB Ram, Komplete Kontrol S88, Komplete 13, DP11, UAD Apollo Twin Duo, East/West Composer Cloud, Vienna, Arturia V8, Yamaha Enspire Pro Disklavier Piano
Re: How do you convert tempo changes into one static tempo
I don't have the answer, but if it were my problem, I'd look to creating SMFs as one possible method. I can't imagine how to make that work without actually fiddling with it. Maybe a dumb idea... Maybe not so much.
IIRC locking the track freezes the MIDI note to their current SMPTE position. So if you import, lock, change tempo, and export, maybe that will do it
Interesting problem. I would try Scale Time. It would be laborious, but the only way I can think of.
Tempo A divided by tempo B would give you a percentage that you would enter in Scale Time and apply to the time range from tempo B to tempo C. Then delete the tempo B tempo change event. Tempo A divided by tempo C would be the next percentage to input into Scale Time, and apply it to time range from tempo C to tempo D. Etc. Or something like that. This is half-baked, but I think the concept would work. Like I said, laborious.
MacBook Pro retina 2015, i7, 16GB, DP 10, M4
Maybe you could pipe the MIDI out to another MIDI recording app (like Garageband).
Just DP set up the ports, and assign the tracks to those ports, and assign them as sources on the destination app, but you know, sans any sync/clocks.
Actually, here I'd probably just record the MIDI on my K2500R
If you have two sequencers, you can always play it from one, into the other.
Disklaviers have sequencers and can record you. Why not just record it into the Disklavier?
Depending on the age of your Disklavier, I might be able to help you do that. I have only used the original DKs, with the little wagon connected by the big fat 1" cable. If that is the kind that you have, I might be able to find my notes on how to set it up to record MIDI from a connection, instead of just from the keyboard. Newer DKs may work the same way, or may not. If we're lucky, they never removed that capability.
I'll look for the instructions.
Ok, on the original Disklavier, to RECORD to the piano from MIDI:
Getting 5 Disklaviers to play together, each with its own parts, is no mean feat. But with Bill's help, and all the team at Yamaha — Terry Lewis and Carter Schull, in particular — we managed. That was 20 years ago, though.
Good luck with your project. If you need any Disklavier/DP help, I'm happy to assist.
PS: You can always record it into another sequencer on your Mac if you can handle the inter-app MIDI connections, or a MTP-AV loop.
- 1) Start up the wagon while holding down VOL, TEMP & TRANS.
2) When you get to the Recording Mode, use the + - keys to move from NORMAL past L/R RECORDING to MDR (MIDI Data Record). The last one is not available unless you start with the above mentioned keys held down.
3) Continue as you would with either of the other two, pressing the RECORD button to begin.
4) Start your sequence in DP. What you record into the piano will be a continuous sequence with no particular tempo attached.
5) [optional] You can record that BACK into the computer, if you want, and have it as a default-tempo sequence in DP.
- pencilina
Hi,
Its totally simple- pretty much what Bayswater said above.
-Lock your MIDI track/s
-Change the tempo to whatever you want (switch from conductor track mode to slider)
-Save as SMF
That's it.
B
-Save as SMF
That's it.
B
boom!
I thought SMFs were involved. Thanks, Penn. nice to see ya!
Whew! That diskclavier was too expensive for me.
