FYI: Master fader in V-Rack with multiple chunks
Hi all;
Just thought I would post this little tidbit- its in the manual, but only if you look for it
I am working on a project and writing several cues for it, all as separate chunks. I decided to put my master fader in a V-rack along with my other VIs so that all the cues would share the same bus processing chain.
It turns out that when you do this, it matters where the V-rack is in the list of chunks. It has to be at the top of the list, otherwise, any chunk above the V-rack in the list will not be routed through the master fader (although the VIs work as expected).
FYI!
FYI!
- FMiguelez
Re: FYI: Master fader in V-Rack with multiple chunks
That's strange... Mine is at the very bottom of all my V-Racks and many chunks, and it works finecrduval wrote: It turns out that when you do this, it matters where the V-rack is in the list of chunks. It has to be at the top of the list, otherwise, any chunk above the V-rack in the list will not be routed through the master fader (although the VIs work as expected).
Isn't there some rule about what happens when you have multiple Master faders? The one to the left (or right) takes priority over the others? Do you have more than one Master Fader in this setup? Could that be what's happening?
- FMiguelez
That could explain it.
The only Master Fader I have is the one at the bottom of my Chunks window. But if there are other MFs inside any other chunks, that's where the conflict might be.
I am positive I don't have any other master faders in my chunks... Maybe it has to do with when the chunk is created relative to when I added the master fader to the V-rack? Here are the particulars:
I had been working on a chunk created prior to adding the master fader to the V-rack. It was at the top of my list of chunks, and the V-rack was in the middle of the list. I wanted to listen to the chunk in mono, so I went to fold it down on the master fader, but the button was grayed out, and there was no audio running through it. I looked at the manual and saw the note about multiple master fader precedence, and thought that it might apply to chunk order when only using one master fader. I re-ordered the V-Rack to the top of the list, and voila, everything worked as expected.
Maybe I can exploer this later today and try to figure out what is going on - but I'm just happy that everything is working
- daniel.sneed
Yes only one master fader at a time. Between V-rack Master faders, priority is top over bottom and left over right.bayswater wrote:Isn't there some rule about what happens when you have multiple Master faders? The one to the left (or right) takes priority over the others? Do you have more than one Master Fader in this setup? Could that be what's happening?
Your attention, please, here's today special case: If you have a master fader INSIDE a sequence AND another one in a V-rack, this will apply too. Sequences *over* the V-rack will apply their own master fader, while sequences *under* the V-rack will apply the V-rack master fader.
Great! Thanx Motu!
dAn Shakin' all over!
