Copying Expression Data
Is it possible to copy MIDI expression data - modulation, MIDI volume, velocity, etc. - from one MIDI track to replace data on another MIDI track? Thanks in advance.
iMac 20,1 10-core, 3.6Ghz, OS10.15.7, 128GB RAM, DP 10.13, VEP7
Re: Copying Expression Data
The problem is selecting the data that goes with the notes you want to copy. That involves converting an event selection into a range selection. There are multiple ways of doing it. Here is how I do it, because it is virtually instantaneous. No menus, searches or anything other than a key command that I set up to be easy and quick. It involves setting up a few commands. Here is the discussion:Rusty Shackleford wrote:Is it possible to copy MIDI expression data - modulation, MIDI volume, velocity, etc. - from one MIDI track to replace data on another MIDI track? Thanks in advance.
Working with Selections in DP
Note: once you understand what the post is saying, and once you have the commands set up, the actual action takes a fraction of a second.
