Duplicate files on import
- Sean Kenny
Hi guys
If there is an obvious answer to this that I should have been aware of, then I apologise in advance, but does anyone know why when I import an audio file from a different DP session (same sample rate bit rate and version) that I always get a duplicate versions, it's so annoying.
Mac Pro 3 GHz 8-Core Intel Xeon E5 - 32 GB Ram 1867 MHz DDR3 ECC - OS X 10.12.4 - DP 9.13 - RME HDSPe Madi card - iz ADA converters 24 i/o - Antelope Orion 32 i/o - Audient desk - Miller & Kreisel Monitors - Wunder Mic Pre's x 8 - very understanding wife!
http://www.ten21recordingstudios.co.uk/
Re: Duplicate files on import
Are they different files, or just different segments within the same files? The durations, starts, etc are different.
Could those be files created by edge edit copying? Perhaps they were already in existence in the original project file, and you're just now seeing them after importing them. Or not... I'm just tossing stuff out there to see what sticks.
When you zoom in on the screenshot you can see theses are 2 sound bites within the same audio file. If there's nothing in the very short SBs, they can obviously be deleted. Sometimes this happens to me when importing, especially from another app.
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
- FMiguelez
How are you importing the audio files?
If you don't want them duplicated on import, there's a setting for that in DP's Preferences. You can opt to have them referenced instead. But you must be VERY careful. I actually wouldn't recommend doing it...
FM, I think we're talking about a different sort of duplication. It's not that the files have been brought into the project from wherever they resided before, but that they seem to have been brought in twice. But on close inspection, there is only one copy of each audio file, but each has two regions defined within it.
- FMiguelez
You´re correct, Bays.
I suppose I didn´t read close enough
- Sean Kenny
Hi Guys
Thanks very much for the replies and apologies for being off the radar for a while, I had a deadline brought forward by a client which resulted in me doing silly hours .... jeez Egyptian slaves get better working conditions than me!!
Further to the comments....... this happens even when I have not touched the original file once recorded i.e.. not edge edited or anything, just copied out of the project by selecting the entire soundbite from either the tracks overview, there sequence editor or the soundbite window, hitting "option R" to reveal the file selected in the parent folder, then just copying and pasting to another folder. The file is then imported "Cmd F1" to a fresh project from this new folder and I still get the duplicate soundbites.
I'll dig a little deeper.
Thanks for taking the time guys
Regards
Sean
Regards
Sean
- tbrianmann
I have had the same issue recently. Same files, same names. Two exact copies of the same audio file. No edits having been done on these. Lately it was files sent to me by a collaborator.
I imported them in the normal, highlighted the files and and clicked the button at the bottom, sorry forgot it's name. DP 8.07 Mac Pro 10.9x
DP 11.22, MacBook Pro M1 ultra, 64 gig memory Ventura 13.41 VePro7x, Play, Spectrasonics, SLATE Complete, LASS, Native bundle, 8dio, Various Plugs, Waves, Metric Halo Interface.
The problem reported above by Sean does not appear to be duplicate files. Look at the image he posted. They are single audio files that contain two regions. It is not clear where the regions were created -- presumably not DP.tbrianmann wrote:I have had the same issue recently. Same files, same names. Two exact copies of the same audio file. No edits having been done on these. Lately it was files sent to me by a collaborator.
- Sean Kenny
They are single audio files that I select to import, which turn into 2 soundbites once imported.The problem reported above by Sean does not appear to be duplicate files. Look at the image he posted. They are single audio files that contain two regions. It is not clear where the regions were created -- presumably not DP.
They were created in DP. They are pre master mixes that are created not from a 'bounce' (i.e. in the box summing) I analogue sum everything through my console and record it back into DP..... in other words they are just ordinary everyday recordings, that are exported for mastering and then imported into a dedicated "Mastering" DP Project, where upon I experience this duplicate soundbite anomaly.
FWIW, it doesn't make any difference what sample rate I'm working at either.
Also worth noting that I have had this problem for quite a while both on my old Intel Mac 2,1 running DP 7.24 on OS 10.6.8 and on my new Mac Pro 3 GHz 8-Core Intel Xeon E5 running DP 8.07 on 10.9.4 ........ weird.
Any ideas?
So if I'm reading this correctly you:Sean Kenny wrote:They were created in DP. They are pre master mixes that are created not from a 'bounce' (i.e. in the box summing) I analogue sum everything through my console and record it back into DP..... in other words they are just ordinary everyday recordings, that are exported for mastering and then imported into a dedicated "Mastering" DP Project, where upon I experience this duplicate soundbite anomaly.
Send to an analog mixer from a project (call it SeanSong) and record back to a stereo track in SeanSong.
Then export this stereo track (file format?).
Next you import the stereo file to a mastering project (not SeanSong).
Is this correct? Let me know and I'll try to duplicate your process on my end and let you know what I get.
Phil
- philbrown
I have the same thing happen here very consistently. If I open the sound file in DSP Quattro is shows no extra regions, markers, etc, but when I drag the same file into DP it creates two slightly different soundbites, exactly like your screen shot shows. It seems to be a long standing bug that has been around through several DP versions.
If it's a DP bug, I don't think it can be very widespread. I've never noticed it. I just checked by dragging an AIF into the TO, importing via the SB window, and opening a new project and recording two tracks, one after the other. In all cases, I got one soundbite per audio file. Splitting them creates new regions as expected, and undo removes the new regions. So it seems like all is working as expected.
Maybe there are some audio file preferences, preferences related to imports, file format, recording prerolls, etc. that account for this.
The feature that records audio prior to hitting record -- wouldn't that create an extra region? DP only places the portion after hitting record in the edit screens, so maybe the earlier part has to be shown as a separate region?
- Sean Kenny
Hi Phil that's exactly right .... thanks for the inputPhil O wrote:So if I'm reading this correctly you:Sean Kenny wrote:They were created in DP. They are pre master mixes that are created not from a 'bounce' (i.e. in the box summing) I analogue sum everything through my console and record it back into DP..... in other words they are just ordinary everyday recordings, that are exported for mastering and then imported into a dedicated "Mastering" DP Project, where upon I experience this duplicate soundbite anomaly.
Phil
