How to filter MIDI signals coming in
I have a MIDI keyboard that's going on the fritz. Its sending random CC84, 74, and a few other messages while I'm trying to score some stuff.
I've tried the MIDI input filter but it doesn't seem to work.
Is there a way to
1. have DP ignore exclusive CC signals coming in while recording?
2. select and delete ALL the CC84 events in a MIDI track? I can't find where to select all specific CC controls. When I highlight the track and delete it deletes notes, Mod wheel info and everything.
Is there a way to
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
Re: How to filter MIDI signals coming in
You can do both, and yes, the MIDI Input Filter does work. You may not be applying it or something. I don't know, but I've used it recently enough to strongly believe that it works without having to test it. Come to think of it, DP 8.07 did come out since I last used it, but I have extreme doubts that that feature got broken in the update. I'll check next time I am working.wonder wrote:I have a MIDI keyboard that's going on the fritz. Its sending random CC84, 74, and a few other messages while I'm trying to score some stuff.
Is there a way to
For now, if you'd like to delete all the CC84 events, just find one such event and double-click it. That should select all events of that type.
If for some reason THAT doesn't work, select a CC84 event and invoke QuickFilter, which is in the bottom left corner of the MIDI Graphic Edit Window, which is the window where you will work most efficiently when doing MIDI. That will hide all data types but the one(s) you selected. You can easily do what you want, then.
Actually, the double-click thing should work. I'm just giving you options.
I don't think I'm using the MIDI Filter correctly.
re: deleting by double clicking, I did find that out yesterday and it was a huge help. The issue is that some of the events are SO small on the sequence window that it's like finding a needs in a haystack.
Also, when I pull the MIDI Edit Layer in the Sequence window, it give me an option to select Controller 84 but I'm scanning the entire track and don't see ANY Controller 84 events. I also looked in the Event Window and don't see and Controller 84 messages either. Unless i'm going blind.
Try the Event Window (the track's contextual menu> Open In-event Window) with the View Filter set to view only CC 84. Easier on the eyes then browsing in the sequence window.
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
Hmm... I don't know why it would do that. Maybe once you've had CC84, the layer is already created and doesn't go away. That shouldn't be the case, though. I'm betting there's one little CC84 dot somewhere in the sequence. Usually, you'll find those at a value of "0" or else a Bar 1|1|000. Those are the places where they get masked by lines in the interface.wonder wrote:I don't think I'm using the MIDI Filter correctly.
Go to the MIDI Graphic Edit Window (really, do MIDI there, not the Sequence Editor, except for special purposes) and look in the controller/velocity panel. Over on the left there is a vertical scale. Click it for some different views. One of those views is Pitch Bend ONLY. If you're in that view, you won't see any controllers. Another view shows Pitch Bend and all other types. The third view shows other types ONLY, and no Pitch Bend. In one of those views you might see the missing dot a little more clearly. You can contract your sequence so that it all fits in one screen, and that's a faster way of searching, visually, for controllers.
Or, you can do as Frank said and use the Event List. That's a quick way, too.
Failing those, select the whole track, then go to the Search menu (Edit/Search) and search for a controller type of 84. If you're in a hurry, Search should be your FIRST stop. You can piggy-back that search on top of the current selection, and it will even delete it for you if it finds anything (and if you tell it to).
Is the keyboard connected via USB or MIDI? If MIDI and you're using a MOTU MIDI interface, you can use Clockworks to filter out controllers on the incoming cable. Although come to think of it, I don't think it can filter SPECIFIC controllers, so perhaps you're better off trying to use DP's input filter.
