Yeah... I'm not sure this is different than DP. I can jump to any song I want to, start playback, etc. using MIDI.wonder wrote:I used DP for live performance for a long time.
I switched to Ableton Live. It's much more efficient for my needs and the flexibility and ease with programming MIDI triggers for Song Start, Switch Songs, etc etc made it an easy choice.
Better way to use DP Live Performance???
Re: Better way to use DP Live Performance???
That's been there at least since about 1990. That's when I remember first using it, and it's a very good feature. You can also call them up with MIDI commands.David Polich wrote:Actually, this is already implemented, in a way. You can assign a Mac key to call up a chunk.Shooshie wrote:I think MOTU should make the Chunks List respond to key-commands like the Tracks Overview.
That has been around since DP 4.61, maybe even earlier than that.
What I mean by responding to key commands is MOVING the chunks around in the list. CONTROL-PageUp CONTROL-OPTION-PageUp [and PageDown in either case], CONTROL-HOME and CONTROL-END move tracks around in the Tracks Overview Window, including stepwise, to the top, to the bottom, gathered and moved to the top (for multiple tracks), and so forth. You can even select a track nowadays from the keyboard. That's what I'd like to see MOTU give the Chunks Window; the ability to reorganize your chunks from the keyboard. And not necessarily just that, but at least that.
