Plug sound Pro on sale
- mhschmieder
Re: Plug sound Pro on sale
It's possible they've gone back and forth on how many files are involved, just like MOTU Ethno.
If you compare your total size on disc to their published specs for library size, compressed vs. uncompressed might be different but not by a factor of two, so that might provide clues as to whether you're missing a second half. Sometimes those are downloaded differently, to minimize piracy.
UVI says there is a one UFS file at 8.28G. I have one UFS at 8.26G. The RAR file was 3.6 which is a bigger than usual compression rate, but not impossible. The file size could be a problem, but could be a difference in how file sizes are expressed.mhschmieder wrote:It's possible they've gone back and forth on how many files are involved, just like MOTU Ethno.
Anyway, I've sent all the details to UVI in a support ticket. I can use UVI workstation in the meantime. What I find odd is if some additional authorization is required or if the library is corrupt, it does not seem to be required or corrupt when using UVI workstation.
- mhschmieder
Here is a link to the presets list, with sizes for each preset:
http://cdn.waycom.net/media/universsons ... s_list.pdf
I'm going to check these details now against MachFive 2 and Ethno 2 to see if they subsume this library.
Here's Sound On Sound's review of the product from when it first came out:
http://www.soundonsound.com/sos/jun07/a ... undpro.htm
Thanks. I'll see if I can figure out how to do a comparison.
The Plugsound Lib (Extreme FX) is identical to the M5 version. Does M5 include the basic (not the demo) soundest? If so, it should be identical as well.
Maybe they changed that? I always needed two files (about 4GB each) to get the thing to work.bayswater wrote:"Both"?? There was only one .rar file to download, and it expanded into one 8.26G UFS file. The UVI site says that PSP is a 8.28G library. Maybe the file is corrupt, but the UVI player can access it OK. Do you have two PSP UFS files? What size are they?MIDI Life Crisis wrote:BOTH UFS files need to be present as I recall, and there is an authorization to be made. That's all my old brain can remember.
- mhschmieder
Well, this is truly bizarre. Disc 1 of MachFive 2 is 8.45 GB and almost exactly matches up with the PlugSound Pro patch list, except it has fewer patches even though it's roughly the same size library! The choice of specific instruments (e.g. a Guild and Martin for acoustic guitars) and near-identical patch names is way too coincidental, but possibly MachFive drew from multiple sources as the church organ patches seem quite different for instance.
Edit: I think I have it figured out. MachFive Synthesis and Sound Design & Fx came from different sources, so the PlugSOund Pro portion is probably ½ to ⅔ of that library, meaning there's a lot of overlap but they aren't completely redundant of each other.
The redundancy factor increases significantly if you own Ethno 2. For instance, MachFive 2 (I didn't yet check my MachFive 3 banks) is missing the Celtic Guitar from PlugSound Pro, but that is part of Ethno 2.
That's what I feared. I didn't have time to do a detailed comparison of MachFive 3 presets and the Plugsound Pro presets. They seem to have a lot of overlap at least in the preset names. Hope I didn't buy too many samples I already have.mhschmieder wrote:Well, this is truly bizarre. Disc 1 of MachFive 2 is 8.45 GB and almost exactly matches up with the PlugSound Pro patch list, except it has fewer patches even though it's roughly the same size library!
There are two files about 4G each for the Extreme FX library, and you need both of them in place to load any of the presets. I have that as part of MachFive. If you also have two 4G files for PlugSoundPro, then I guess that has been changed.MIDI Life Crisis wrote:Maybe they changed that? I always needed two files (about 4GB each) to get the thing to work.bayswater wrote:"Both"?? There was only one .rar file to download, and it expanded into one 8.26G UFS file. The UVI site says that PSP is a 8.28G library. Maybe the file is corrupt, but the UVI player can access it OK. Do you have two PSP UFS files? What size are they?MIDI Life Crisis wrote:BOTH UFS files need to be present as I recall, and there is an authorization to be made. That's all my old brain can remember.
Didn't see this. I'm talking about PlugSoundPro, http://www.uvi.net/en/composer-tools/plugsound-pro.htmlMIDI Life Crisis wrote:The Plugsound Lib (Extreme FX) is identical to the M5 version. Does M5 include the basic (not the demo) soundest? If so, it should be identical as well.
not the Extreme FX library http://www.uvi.net/en/synth-sound-design/xtreme-fx.html
Support says the current PSP library version requires Mach Five 3.2.1. I had 3.2.0. It need the latest UVI player as well. Works now.
Doesn't Plug Sound Pro have licensing restrictions about using the sounds in commercial music. I think I remember buying it a few years ago (it was one of my first sound libraries), and then being turned-off by the restriction notice.
Mike
Mike
Wouldn't be much of a "pro" thing if they did. I don't see it in their EULA and even if they did, I doubt it would be enforceable. Seriously, how could they tell it was theirs and who would be "policing" it. Personally, I ignore that in VIs. Sample libraries do sometimes limit you as well but the same reservations apply. How do they prove it and who is listening to commercial products and listening for infringements - especially in a mix?MikeInBoston wrote:Doesn't Plug Sound Pro have licensing restrictions about using the sounds in commercial music. I think I remember buying it a few years ago (it was one of my first sound libraries), and then being turned-off by the restriction notice.
Mike
I wouldn't give that a second thought.
EULA (End User License Agreement)
UVI allows you to use any sounds from UVI libraries (even in its original state) within a musical or sonic composition with no problem. You can also use the sounds in a composite of sounds BUT you aren't allowed to use the sounds as single elements in a competitive product.
