Just got Grosso - pretty cool. A little "construction kitty" for me, but will work nicely in spots!
I've been working in 4/4 in a triplet feel, but Grosso is all 12/8 and I'd have to translate everything from 4/4 -> 12/8 to get Grosso to be in sync. Any suggestions other than doing this manually? (Is there a way to send Kontakt different tempo sync info or set it manually?)
Thanks much!
Grosso/Kontakt Sync
Grosso/Kontakt Sync
MacPro 2011 *upgraded* 12 Core 3.33. 64 Gigs RAM. 2x PCIe SSDs, 2x SATA SSDS - OS 10.10.5, DP9.02, VEP5 + VEP5 Slave PC (i7)
Re: Grosso/Kontakt Sync
I think running Grosso at 90BPM gives you the desired 4/4 adjustment. There is a video on that and is also in manual if I recall correctly.
Hope that helps.
Hope that helps.
Yeah - but I think it's supposed to stretch to any tempo. Not sure if it's a DP or Kontakt or Grosso issue. Their support seems responsive. Cool library! Thx!
