Dear Community
I have a sequence which consists of MIDI tracks, audio tracks and virtual instrument tracks. I'd now like to duplicate this sequence. This works well, except that the instrument assignments get messed up (each instrument is assigned to one or more audio track's inputs).
I know that I can move these instruments to vracks, but for these instruments I don't want to (I might edit an instrument in the duplicated sequence, but want the old one to stay the same).
Could you give me any advice on this? Thanks a lot.
Cheers
Remo
Duplicate a sequence with virtual instruments
Re: Duplicate a sequence with virtual instruments
Are you using "Duplicate Sequence" from the Chunks window mini menu?
I haven't had output assignments get messed up when I've used that function.
Are you using stereo busses to get from VI out to audio track input?
In the meantime, here are some useful shortcuts when dealing with the tedium of re-assigning tracks:
1. Select MIDI track(s)
2. SHIFT-UP/DOWN ARROW to change output device/VI
3. OPTION-UP/DOWN ARROW to change output channel
4. SHIFT-OPT-UP/DOWN ARROW to move selection to next track
Notice that you can select a group of tracks and change the device/VI and it will retain the MIDI channel setting. If you change the MIDI channel of multiple tracks it will nudge each channel setting up/down one-at-a-time relative to its previous value.
- doodles
WOAH. stubbsonic, What the heck? How did I never know about this? (er, because I never read the manual?!)stubbsonic wrote:1. Select MIDI track(s)
THANKYOU!!!
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
Pretty straight up - - just go to the Chunks window, select (highlight) the Chunk you're working on, command-C (copy it), command-V (paste it) and you'll get a duplicate (including all of your stuff) in your chunks window.fatnack wrote:Dear Community, I have a sequence which consists of MIDI tracks, audio tracks and virtual instrument tracks. I'd now like to duplicate this sequence.
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
Yea. I went FAR too long without knowing those shortcuts. Those fall into the essentials category, for sure. Glad they helped you.doodles wrote:
THANKYOU!!!
