Waves Renaissance Reverb in DP7?
nickysnd
Post by nickysnd »
Anyone using it in dp7? Waves specifications sez dp8...
Mac mini Apple M1 ♦ 8GB RAM ♦ MacOS 14.4.1 ♦ Focusrite Scarlett Solo ♦ DP 11.31
Re: Waves Renaissance Reverb in DP7?
It depends on the version of Ren Reverb you're using. I've had it working with DP for many versions, but only certain versions of Waves will work with certain versions of DP, or other DAWs. It's possible that the latest version of Ren Reverb only works with DP8, or at least has only been tested by Waves with DP8.
nickysnd
Post by nickysnd »
Thanks, I'll get the trial version and see.
Armageddon
Post by Armageddon »
I have Waves 8, Snow Leopard and DP 7.24, and Renaissance Reverb (again, for Waves 8 ) works great, as does every other Waves 8 plug. Unless I'm mistaken, the main criteria for Waves 9 is having Lion or higher as your OS. Also, I think there's a chart on the Waves site that shows you what OS/DAWs Waves 9 works with. For a while there, DP wasn't supported at all with Waves 9. Why not just download the demo?
nickysnd
Post by nickysnd »
I did and it works.
