Change multiple velocites on one MIDI note
Jera
Post by Jera »
Hi
I have a MIDI track that was recorded with a TD-20, the kick drum of the MIDI track has a very low velocity, I would like to change all of them to 127, is there a way I can make it all the same for a single note?
Chris
DP 8.6 / MacBook Pro 2.7ghz Core i7/8GB ram/Dell Latitude 7440 i7 16GB RAM /1TB Firewire 800/828 original/Midisport 2X2/MIDI merger
NazRat
Re: Change multiple velocites on one MIDI note
Post by NazRat »
Open the Drum Editor and double click on the note name (left panel) you want to change to select all the hits. Then right-click on any of the selected hits and pick Change Velocity. In the Change Velocity dialog select 'Set' from the dropdown box and the enter the number you want.
(You can see the change if you show 'Grid with Velocity' setting with the down arrow just to the right of the Comments column for that note.)
DP8.06 PT11.2.0 VEP 5.3.x
Or open the track in the MIDI editor and double click on the piano key to the left for the note to be changed. Then you can choose the Change Velocity command, or drag the velocity icons in the lower half of the edit screen up and down.
