Sequence of upgrades for 64 bit
I apologize if this has been answered elsewhere, but I could not find an answer to this specific question: If I want to join the 21st century and go 64 bit on my Mac Pro, what is the recommended route? Do I start with DP and then the VI's and then the OS? Or do I do the OS first and then the others? Does it really matter what order I do the upgrades in?
For reference, I am in OS 10.6.8 and I am using DP 7.24 with a wide variety of VI's, but primarily Kontakt 5, E/W Play, Mach Five 2, Trillian and Stylus RMX, Ethno 2, Sampletank 2.5 (bu-bye!), Addictive Drums, Alchemy (love it!) all on an early 2008 Mac Pro. Also, will I need to do anything special to continue using my 828 Mk. 3 and my MIDI express xt?
I'm assuming that I will go the full Monty to the latest version of Mavericks and DP 8.0.6, but I am open to hearing reasons that I should not do so.
Thank you!
Thank you!
2018 Mac Mini 3.2 GHz Intel Core i7 with 32 GB RAM and 2 TB SSD
Monterey 12.6.1, DP 11.21 64 bit. Mach Five 3, Ethno 2, Omnisphere, Trillian, Stylus RMX, EWQL Play, Kontakt 5 with various libraries, Absynth 5, Sampletank 3, Realstrat 3, Alchemy 1.55, Addictive Drums, lots of other goodies.
MOTU MIDI express XT, MOTU 828 Mk.3 firewire and Novation 61 SL Mk. II
Re: Sequence of upgrades for 64 bit
DP 7.24 works in Mavericks. It will remain 32bit but most of your plugs will still work in it - unless they were old PPC apps that need Rosetta to work in 10.6 - those won't work at all from Lion on.
Some of your 32bit plugs will not work in 64bit; others will if you use wrappers like J-Bridge (VST) or 32lives (AU).
MachFive 2 will not work as a plugin in DP 8 64bit but will stand-alone or as a plug in 7.24 or 8 32bit.
Tons o' threads on these subjects now. Use the search function now that I've given you some terms to search for.
- FMiguelez
When I changed my G5 for Mac Minis, doing a clean instal worked wonders for me.
I started with the OS. I got Mavericks and then I made sure I had the latest update.
DP followed. I did some tests at this point, and everything worked.
From there, I started installing all my plugs and VIs. It's a lot of work, but totally worth it. Having a clean instal and only audio apps, seem to agree with a dedicated studio computer.
- FMiguelez
Mine works perfectly, Mike. Actually, it ONLY works as a plug-in here. If I try it hosted inside VE Pro, I get constant crashes and stuck notes.mikehalloran wrote:
Unless I've been running it in 32 bit mode and don't know about it (but I don't think so. How can I know for sure?)
Maybe you have been running in 32 bit mode? Was MachFive available as an AU? Perhaps it was and you're using it inside a wrapper? I thought it wouldn't work, but I may need to look again. I have MachFive 3 anyway, so I guess it's not a big deal.FMiguelez wrote:Mine works perfectly, Mike. Actually, it ONLY works as a plug-in here. If I try it hosted inside VE Pro, I get constant crashes and stuck notes.mikehalloran wrote:
That works for me in DP8 64-bit with 32 Livesbillgers wrote:Sampletank 2.5 (bu-bye!)
I have helped diagnose the problem in a couple of threads - MV2 can't be seen by DP 8 but works standalone. The user changes DP 8 to 32bit and there it is. Then someone posts that it's time to upgrade to MV3 and so on...
Starting with MachFive 3, I don't have a way of duplicating the results.
- FMiguelez
James Steele wrote: Maybe you have been running in 32 bit mode? Was MachFive available as an AU? Perhaps it was and you're using it inside a wrapper? I thought it wouldn't work, but I may need to look again. I have MachFive 3 anyway, so I guess it's not a big deal.
I am SO SORRY, guys!mikehalloran wrote:I have helped diagnose the problem in a couple of threads - MV2 can't be seen by DP 8 but works standalone. The user changes DP 8 to 32bit and there it is. Then someone posts that it's time to upgrade to MV3 and so on...
I didn't see the 2 in the MachFive part... My brain just saw the MachFive part and it assumed it was MF3
Note to self:
When I find something about hardware that seems to contradict what MIke Halloran says, I should really double check my facts (or reading) first.
Thank you everybody for the responses. I know this will be a lot of time and energy to do all the updates, but I feel like I really need to escape the RAM limitations of 32-bit. I am hoping that by going 64 bit, I can continue to use my ancient computer well into the future, since the only thing that really gives me trouble is projects with lots of sample data.
I guess I should be thankful that at least I'm not dealing with the limitations of my old rack of Akai hardware samplers (still useful to have around as a light show when a client needs to feel the bling factor).
