I scoured the manual and googled for everything I could think of. I'm stumped.
Is it possible to have a single command to stop the recording, delete the recorded soundbite, return to beginning and start recording again (selectably with/out preroll)?
I managed to find this feature in Logic as 'Record Repeat' and in Cubase as 'Re-record Mode', if that helps the reader understand the functionality I'm looking for.
Retake, Record Repeat, Rerecord.. in DP?
- Robert Randolph
- FMiguelez
Re: Retake, Record Repeat, Rerecord.. in DP?
Not like that, but you can accomplish the same thing with auto-rewind on (so it goes back where it started) and undo.
You could probably program a QuicKeys macro as well.
I set up commands and have a little "dance" of key presses.
I use the spacebar to stop, COMMAND-z to undo recording, and I use numeric-keypad's zero to rewind to beginning, I have a couple different key-commands to enter recording, depending on whether I'm using my laptop with or without an attached keyboard.
So I'm recording a pass, and I don't like it--- bip, bam, boom, pop and I'm back in again.
- philbrown
I never use it, but would Polar work for this?
In a way, Polar would work. But Polar is designed for things like stacking harmonies, stacking an entire song from the ground up. You could use it for takes though.philbrown wrote:I never use it, but would Polar work for this?
Polar is highly RAM dependent. Be sure you have plenty of it!
