Quick way to mute or solo a MIDI track?
In Cubase, I'm used to working on a MIDI track, then hitting 'S' to solo it very quickly. Is there a way to do this in DP? Similarly, is there a way to mute a MIDI track with a keyboard command?
Re: Quick way to mute or solo a MIDI track?
For Mute function check out the Play Enable command.
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
- doodles
Yep, that's exactly what I do. Just set it up in the commands menu.MDesigner wrote:In Cubase, I'm used to working on a MIDI track, then hitting 'S' to solo it very quickly. Is there a way to do this in DP? Similarly, is there a way to mute a MIDI track with a keyboard command?
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
I don't see a "Play Enable" command I can bind a shortcut key to, unfortunately. Am I missing something? I'm just looking for a single keystroke that will mute toggle a MIDI track.
Any of the commands with "..." will bring up a dialog, which is an extra step. I'm looking for something super quick.
Also I'm looking for a single key command to solo a MIDI track.
- doodles
in the commands, look for solo/toggle solo mode. assign the letter S (or whatever)
Then, in future, when you press s, you enter solo mode.
Yeah, solo mode kinda does the trick. In pretty much every other sequencer, you can just click the "S" on a track and solo it. I can do that in DP in the mixing board, but I feel like there should be a way to quickly/easily solo a track in the tracks, sequence, or MIDI views. The channel strip works, I suppose, but there ought to be a way to bind a key to that solo button.
I'll put this in as a suggestion.
For single button push in any window you could use DP’s MIDIKeys to generate Note-On messages along with DP's Control Surface setup.
With Mackie Control protocol, for Solo, MIDIkeys needs to produce notes in the range G#-1 for Solo 1 to D#0 for Solo 8 where middle C = C4
DP/Setup/Control Surface Setup
Driver Mackie Control
Unit Mackie Control
Set Input Port to MIDIKeys
implementation chart:
http://home.comcast.net/~robbowers11/MCMap.htm
MidiKeys (note the lower case) alternative to MIDIkeys, might be useful with Quickkeys or Controllermate, cause MIDIkeys will likely impact other useful shortcuts. www.manyetas.com/creed/midikeys.html
MIDImonitor is handy when setting this up.
http://www.snoize.com/MIDIMonitor/
Unit Mackie Control
Whoa!
And in Cubase, all I have to do is hit "S" on the keyboard to solo the current track.
This is something I'll definitely be talking to MOTU about. Thank you for the tips though!
I don't use Cubase, but if that is how solo works, then IMO, DPs solo modes are much deeper. Search for threads here and in the manual on solo mode for info. At its simplest, in the edit windows, when you toggle solo mode the tracks that were last in the solo "group" are retained and soloed. You can then solo 1 track only by opt-clicking the track's play button. I certainly would not want to see the paradigm you describe in DP.
Frank Ferrucci
http://www.ferruccimusic.com
- FMiguelez
+1frankf wrote:I don't use Cubase, but if that is how solo works, then IMO, DPs solo modes are much deeper. Search for threads here on solo mode for info. At its simplest, when you toggle solo mode the tracks that were last soloed
DP has essentially 4 Solo states. It is extremely powerful to be able to use any of those states with key commands at any given time. My favorite is the Solo Front-most Window mode. Also, using command or option to set the soloed tracks (all except/only this, respectively), is a total time saver!
Deeper is not always simpler.. I need quick/simple.
Felix: NOW you've piqued my interest. Solo front-most window?? That's exactly what I'm looking for. So if I'm editing in the MIDI window on a particular track, I want to very quickly just solo that track. How do I do that? (besides clicking the solo button on the channel strip.. I'm more of a keystroke guy)
- FMiguelez
That's a very cool feature.
It will work regardless of the other solo states.
To set it up, simply option-click on the Solo button in the transport. That will open the Solo Preferences, where you click that option. This way you can quickly toggle it on or off. There might even be a more direct shortcut for this.
When you set it like that, any window which happens to be the front most one, will solo the tracks that are visible in that window. Notice that you could also set it to "by percentage" to still hear only a little of the un-soloed tracks, if you wish.
The mixer works like you expect.
I edited my post above, so I don't know if you saw my last sentence (using command-click or option-click on a track's Play-enable status).
Ahh, solo mode is great for the MIDI window. Thanks for the tip!
Now, the only other issue I have is soloing a folder of tracks. I often do this to check percussion by itself, etc. Maybe I'm doing it wrong, but it takes a few steps to unsolo.
To solo percussion is simple: option-click the play enable button for percussion.
To "un-solo" percussion is two steps unfortunately:
1) Command-click percussion play enable (this disables percussion but re-enables everything else)
2) Click play enable on percussion; now everything is re-enabled
PS: The percentage velocity idea is pretty brilliant, but unfortunately it won't work with many sample libraries, as it's often the case that the loudness/dynamics is controlled by CC1, not note velocity.
- FMiguelez
You can simply click the play-enable button directly in the folder (if it was enabled, this will disable it, and viceversa).
But this is a scenario where both solo states can be so useful. For instance, you can have a state to play everything (nothing muted), and then press the Solo command to hear only the percussion section, with no further tweaking. You just set it up once, and both states will be a shortcut away.
Notice that if you don't have a folder, and your tracks are contiguous, you can click on the first track's play enable button and drag down the list spanning as many tracks as you want, so there's no need to click and click and click. That works for all buttons in all editiors
