When I apply the shift command to my MIDI data, it messes up the chords but I can't figure out why.
Of course I did read the fine manual again , but something is still clearly wrong.
Anyone know what's going on?
Here's a 10s movie showing the problem. I'm trying to simply shift the chords 30 ticks earlier to sync better with the rhythm track.
http://talkstudiousa.com/shift.mov
Greg
Shift command messes up MIDI chord data…why?
- synergy543
Gregory D. Moore DP11.1, OSX 10.14.6 MacPro 2013 8-core, 64G RAM, too-many sample libraries, pencil, paper, coffee, and midnight oil.
- FMiguelez
Re: Shift command messes up MIDI chord data…why?
I had never seen that.
Does it make a difference if you make a time range selection, i.e., with the beam tool?
Does it work correctly if you use Shift to move the notes later?
- Dan Worley
Makes no sense. Try a restart (if you haven't already). Uncommon/Incorrect behavior in DP is often corrected by a restart.
DP10.13
Sounds like that bizarre View Filter bug.
Copied from another dificult to follow tread:
"There are some new options on Setup>Set View Filter, notably - under Notes - "Normal", "Display Only", "Playback Only". I had to plow back through the manual (thank God for the manual) to find out what these new options were all about. They're *SUPPOSED* to be all about QuickScribe (and Quickscribe only?), but - at least on my system - *THEY* are the cause of "auto-copy". Here's the deal; you have to have "Normal" checked or you won't see any notes at all, but - with "Normal" checked - UnCheck *either* "Display Only", "Playback Only" or both, grab note(s) in any editing window except Quickscribe, drag that note(s) to a new location. If you've (unintentionally) copied the note(s), Undo, check *both* "Display Only" & "Playback Only" and try again. No copy made? That was my result."
The whole thread:
http://www.motunation.com/forum/viewtop ... =auto+copy
The whole thread:
Just for info purposes, it might be useful to see if there is something consistent about the notes that don't disappear and/or those that do. Their timing info (beat address), and velocity?
Not saying this isn't a bug. It clearly is.
