Codec converter
Codec converter
Hey guys, can anyone recommend a good codec converter plugin to take mastered files to iTunes . Thanks
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: Codec converter
Toast 11 and DSP-Quatro are easy and good... If you have Wave Burner with Logic 9, that still works.
Although DSP-Q is still 32bit Carbon, 64bit Cocoa is supposed to happen soon. The only issue is that some Cocoa based plugins including a couple from Izotope won't work properly such as Ozone 5.04 (5.03 and 5.05b work fine). Anyway, a lot of people use DSP-Q for mastering and to prepare files for iTunes and CD mastering.
I happen to have all three and use Toast for that. Can't be easier.
Re: Codec converter
I use Codec Toolbox from Sonnox.
It's a two steps process:
First a plugin that you put last in your master chain. It converts in real-time to the format you choose. The plugin shows the nmr infos and warns of overs. That allows you to adjust/remix accordingly while earing the final conversion in real-time with clip-safe auto-compensation.
Second, a stand-alone software, Toolbox Manager, to batch convert and metadata inputs.
Very satisfied with it.
iMac Pro 3 GHz 10-Core Xeon E5, 64GB ram OS X 10.15.7, UA Apollo 8 Quad + Satellite Quad, UA 2192, Waves V12, LASS Full, VSL, Korg MS-20, Elektron A4, Moog SlimPhatty, NI Komplete13, ROLI, Soundtoys 5, Arturia V Collection, GForce Oddity, Serum.
