Direct play through recording
ritzybiz
Post by ritzybiz »
DP 8 On my new MacBookPro has direct play through greyed out. I am using an Apogee Quartet and latest Mavericks OS. I have never come across this before and any suggestions would be appreciated.
Sent from my iPad using Tapatalk HD
iMac 2019, 40 GB RAM
MacBook Pro, 16GB, OSX 10.11
DP10, Studio One, PT, Logic X, Sibelius, Live, Reason
Apogee Duet, Apogee Ensemble
Dan Worley
Re: Direct play through recording
Post by Dan Worley »
You can only get Direct Hardware Playthrough with MOTU interfaces. You will need to either lower the buffer or use Apogee's low latency mixer (the latter is probably your best option).
DP10.13
ritzybiz
Post by ritzybiz »
Dan Worley wrote:You can only get Direct Hardware Playthrough with MOTU interfaces. You will need to either lower the buffer or use Apogee's low latency mixer (the latter is probably your best option).
Thanks Dan
