http://www.osculator.net/forum/threads/ ... 89fed133d4
I've been trying it and is's pretty interesting. It works with the Mackie protocol, so banks won't automatically refresh when you select them on DP (like V-controller), but seems to work well as a command/shortcuts controller and basic mixer.
Did you guys see this (TouchOSC template for DP)
- fsheinfeld
Re: Did you guys see this (TouchOSC template for DP)
Thanks for posting this.
Thanks for posting - I just tried this out and it really helps my work flow. Having one touch access to all those hidden menus and functions makes things much quicker - and it was relatively easy to set up. Thanks tons.
Imac 27" core i7 (3.5ghz), 15" Macbook Pro 2.8ghz Core 2 Duo, UA Apollo Quad 800 firewire, Mackie Onyx 400f firewire,Euphonix MC Control, Euphonix MC Mix, DP 8.04 , Logic 9. AMPGUI Mods "Sharp", "Dark", "Snow", "Mellow"(electric blue).
- fsheinfeld
Glad it helps. I've been also exploring Lemur and created some shortcuts and a template for DP. Still a work in progress, but so far is working ok.
Hey guys if you like this template I just posted an update for it.
I fixed the automation hangup so now it works as it should and added a User block for your own commands as well as a couple of extra commands.
you can grab it from:
http://www.osculator.net/forum/threads/ ... ut-For-DP8
or my site:
bleachstuff.com
Thanks for sharing!
or my site:
bleachstuff.com
Thanks for sharing!
