How are tracks in the MIDI editor audio enabled
Dumb little thing that is eluding me. Some tracks don't produce an audible note when I select them in the editor. Other tracks are fine, and I can hear all the notes when I click on them. I've checked them to be play enabled in the tracks and mixer...they appear in the track selector....I know there's some activator I'm missing. thanks for the help
i7 2.93ghz iMac SSD & 16gb•DP7.2/9•StudioLive1642•Joe Meek 3Q•ADK Humburg T-67•ADK Vienna•Rode NT2•Taylor GS Koa limited•'71 Gibson Hummingbird•Fender Strat Plus w/lace sensors•Fender P bass•JBL 2325's•MOTU microlite•Tascam DAT•Alesis QS8•Yamaha U3•Ravenscroft 275 VI•Nord Piano•Specialized Stumpjumper Elite
Re: How are tracks in the MIDI editor audio enabled
If you are working with a VI, open that VI window and in the little mini menu on the upper right corner, check the option "Run this instance in realtime" (or something like that). That will make those shy notes start making some sounds.
- Guitar Gaz
Never thought about that one - I usually just put the track record button on and that makes the editing audible.stubbsonic wrote:If you are working with a VI, open that VI window and in the little mini menu on the upper right corner, check the option "Run this instance in realtime" (or something like that). That will make those shy notes start making some sounds.
Gary Shepherd
____________
____________
I have never noticed that. Didn't get a chance to try it yet. Sounds like that should do it...I hope. thanks
stubbsonic wrote:If you are working with a VI, open that VI window and in the little mini menu on the upper right corner, check the option "Run this instance in realtime".......
