Is there a key command, or can I set one up, to select from this menu?
https://www.dropbox.com/s/y3ithjjfkvqeo ... .48.58.png
Basically I want to be able to swap between drawing Volume, Modulation, etc. without having to go to my mouse every time. Thanks!
Can I change the which type of CC with a key command?
- FMiguelez
Re: Can I change the which type of CC with a key command?
You will need something like QuicKeys to program macros for that.
It's what I do, and it works beautifully. You really save so much time by not mousing around so much...
Cool! I'm giving the Quick Keys application a trial, seems good so far.
