Hi Everybody!
After using DP in my school's studio for a year, I took the plunge and bought it for my home machine. Glad to be here.
If possible, I'd like to find a way to automate velocity scale either via CC or automation. I often need to automate velocities of drum set parts, since automating CC7 doesn't have the correct effect on fixed decay samples. The problem is automating a crescendo, for example, that keeps the accents and ghost notes (i.e. relative velocities) intact.
While I could use the change velocity function, this is a destructive edit and limits flexibility should I change my mind later on in a project. For this reason, I find it much easier to automate, therefore separating the relative velocities from the global velocity level.
I realize that the MIDI plugins can't be automated, so I was hoping that custom consoles would be the solution. From what I've found, it doesn't seem like they can do what I'm looking for, but perhaps I need to dig a little further.
Does anyone know of a way to get the results I'm looking for?
My current workaround is to host all of my fixed decay samples in Bidule. Within that environment, I set up a chain that controls velocity scale via CC3. This works for now, but once I get a slave machine and start running VE Pro, it would be much easier to have this control over my MIDI data within DP.
Any ideas?
Automate Velocity Scale via CC
Mac Studio M2 Ultra (192GB RAM) | macOS 13.5.2 | MOTU M4 | DP 11.3
