Converting an audio track of a kick drum into MIDI data
goosetunes
Post by goosetunes »
I've searched the manual without luck… so can anyone tell me if there's a way in DP 8.05 to create a MIDI track that synchs to the beat of an audio kick drum track? I've seen it done in Cubase where using beat detective you can create a synched MIDI track which you can then use to trigger VST samples to help beef up your kick drum sound. :headbang:
Any help would be greatly appreciated!
DP 9.52, MachFive 3, MX4, Kontakt5, Omnisphere, PLAY, 828mk3 Hybrid FW-USB2, 8-Pre, MIDI Express XT, Mid-2012 MacPro 2 x 3.46 GHz 6-Core Intel Xeon, 64 GB RAM, Graphics Radeon RX 580 8192 MB, OSX 10.14.6.
Re: Converting an audio track of a kick drum into MIDI data
Have a look at the Trigger plugin in the manual.
For a discussion on Trigger's merits and some alternatives, see here http://www.motunation.com/forum/viewtop ... er#p479388
and here http://www.motunation.com/forum/viewtop ... er#p479964
If basic beat detection is what you really want, you can find it in Chapter 50 of the manual.
dpg4macman
Post by dpg4macman »
I haven't tried this so it may or may not work. Couldn't you just select the "pitch" option on the audio bass drum track - copy and paste to a MIDI track. assign a VI with your favorite drum sample. ??
