I've searched the manual without luck… so can anyone tell me if there's a way in DP 8.05 to create a MIDI track that synchs to the beat of an audio kick drum track? I've seen it done in Cubase where using beat detective you can create a synched MIDI track which you can then use to trigger VST samples to help beef up your kick drum sound.
Any help would be greatly appreciated!
Converting an audio track of a kick drum into MIDI data
DP 9.52, MachFive 3, MX4, Kontakt5, Omnisphere, PLAY, 828mk3 Hybrid FW-USB2, 8-Pre, MIDI Express XT, Mid-2012 MacPro 2 x 3.46 GHz 6-Core Intel Xeon, 64 GB RAM, Graphics Radeon RX 580 8192 MB, OSX 10.14.6.
Re: Converting an audio track of a kick drum into MIDI data
Have a look at the Trigger plugin in the manual.
For a discussion on Trigger's merits and some alternatives, see here http://www.motunation.com/forum/viewtop ... er#p479388
and here http://www.motunation.com/forum/viewtop ... er#p479964
If basic beat detection is what you really want, you can find it in Chapter 50 of the manual.
I haven't tried this so it may or may not work. Couldn't you just select the "pitch" option on the audio bass drum track - copy and paste to a MIDI track. assign a VI with your favorite drum sample. ??
