DP 8.06 Is Available
- adriano
Downloading right now.
Adriano
Adriano
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
- FMiguelez
Re: DP 8.06 Is Available
Nice!!!
From their website:
http://cdn-data.motu.com/site/docs/dp/v ... readme.pdf
From their website:
MOTU wrote:Enhancements introduced in version 8.06 Version 8.06 provides many improvements, optimizations, and refinements. Here are just a few highlights:
• Added new Guided Lessons, which provide integrated, interactive tutorials. See the new Guided Lesson project in Application Support, or download it as part of the updated tutorial materials from motu.com/download. • Improved operation with multiple Core Audio devices running under 10.9. • Sends can now be dragged and dropped in the mixer, just like effect settings.
• Support for Japanese text input on Windows. • Improved importing crossfades from OMF and AAF files. • Improved operation on Windows with drag and drop, window focus, instrument aux assignments, and the Movie window. • Fix for an issue on Windows where Digidesign Accel HD hardware wouldn't change sample rate. • Addressed several issues related to Movies and Load. • VIs now retain their aux assignments when duplicating a chunk. • Improved compatibility with Scuffham S-Gear plugins. • Video output offset now works with MOTU video hardware and DV output, even when DP is resolved to an external time base. • Improved compatibility with UAD plug-ins on Windows. • MIDI tracks now retain output assignments to V-Rack VIs when loaded from a document containing the same V-Rack. • Fixed a problem with icon menus in plug-ins on Mac OS X 10.9 systems
- FMiguelez
How COOL is that?MOTU wrote: • Sends can now be dragged and dropped in the mixer, just like effect settings.
I hope sends default to - infinity now, please...
Meh...MOTU wrote: • Support for Japanese text input on Windows.
- adriano
Meh...[/quote]MOTU wrote: • Support for Japanese text input on Windows.
Hey, watch it!
Thanks for the heads up.
Can't wait to download!• VIs now retain their aux assignments when duplicating a chunk.
iMac Pro 3 GHz 10-Core Xeon E5, 64GB ram OS X 10.15.7, UA Apollo 8 Quad + Satellite Quad, UA 2192, Waves V12, LASS Full, VSL, Korg MS-20, Elektron A4, Moog SlimPhatty, NI Komplete13, ROLI, Soundtoys 5, Arturia V Collection, GForce Oddity, Serum.
- Dan Worley
Not sure if it's necessary with this update or not, but everyone might want to rename the 8.05 app file before updating so this update doesn't overwrite it.
Overwrite never used to happen with DP updates, but 8.05 did overwrite 8.04.
It's good to have both versions around for a while so you can compare any behavior changes between them for troubleshooting purposes, or go back to the old one in case the new version gives you fits.
Of course, with Time Machine it's really not that big of a worry.
DP10.13
Sadly, even though the Read Me states that 8.06 offers improved compatibility with Scuffham
Amps plug-ins, the problem of Crash-On-Quit from projects containing Scuffham plugs has
not been fixed.
It's not a huge deal because I've come to expect the COQ with any project that has Scuffham
amps, and I don't bother to send the crash report anymore.
It's still a tad annoying, though.
not been fixed.
http://www.davepolich.com
My experience is that you have to make a copy of DP and rename that.Dan Worley wrote:Not sure if it's necessary with this update or not, but everyone might want to rename the 8.05 app file before updating so this update doesn't overwrite it.
Time Machine will be ok to restore from.
Also got crash on quit (haven't had that before the update). I started a thread for bugs and such... just to put those reports in the right section.
http://www.motunation.com/forum/viewtop ... =1&t=57002
- Dan Worley
The updates are full versions now so there's no need to make a copy. Just rename DP's app file before installing the update, e.g., "Digital Performer (8.05).app"dix wrote:My experience is that you have to make a copy of DP and rename that.Dan Worley wrote:Not sure if it's necessary with this update or not, but everyone might want to rename the 8.05 app file before updating so this update doesn't overwrite it.
The update will write as Digital Performer.app
DP10.13
Inserts still at zero.FMiguelez wrote:I hope sends default to - infinity now, please...
Meh...
For the record, the READ ME:
- FMiguelez
bayswater wrote:Inserts still at zero.FMiguelez wrote:I hope sends default to - infinity now, please...
Meh...
Do they really work like plug-ins? I mean, can you move, copy or delete multiple sends at the same time from channel to channel (dragging objects)?? If so, that is really nice and would expedite send setup by a lot.
- BKK-OZ
Any word on the tempo-based effects issues?
Cheers,
BK
- M Kaku
BK
- M Kaku
