SSD for Boot Drive...?
Re: SSD for Boot Drive...?
I have to check and make sure my machine can handle a 5th drive but that would be totally awesome! Thanks.
Last edited by MIDI Life Crisis on Thu Feb 20, 2014 3:47 pm, edited 1 time in total.
- cbergm7210
If you have an open PCIe slot you're golden. I actually yanked my dedicated firewire card that was being used for Liquid Mix (which I purposefully abandoned a year ago) to free up a slot.MIDI Life Crisis wrote:I have to chaco and make sure my machine can handle a 5th drive but that would be totally awesome! Thanks.
http://www.rfjmusic.com
Chaco? What was my spell checker thinking... ok, here's the scoop.
On a 2008 MP (which is what i have) if the SSD card is inserted into the extended PCIe slot next to the graphics card, you get the full throughput of the SSD as well as that same throughput for the two eSATA ports.
OTOH, if you place it in ANY OTHER PCIe slot on the machine, the throughput drops to below SATA (so don't do that!)
http://eshop.macsales.com/shop/SSD/PCIe ... lsior/RAID
Still, a $1,000 is a lot of clams for a drive but the other drives do seem like distinct possibilities now. Thanks again for the info, guys. Here's the OWC item:2008 Mac Pro
These models have two x16 PCIe 2.0 slots, which enable Acceslsior to deliver full throughput up to 688MB/s. Installing Accelsior_E2 into one of the two x4 PCIe 1.0 slots will result in Accelsior_E2 being addressed as a gen one, one-lane card with performance limited to real world 190-200MB/s data rates.
- cbergm7210
Lots of good options for sure. I was going to do the PCIe for my VI's then swap out my SATA boot drive for an SSD as well, but my late 2009 MP would have maxed out at the 3G SSD for the boot drive, which is not just a little slower than the Mercury Accelsior_PCIe option. So I went ahead and sprang for max speed and put everything on the PCIe super car. In for a dime...MIDI Life Crisis wrote:Chaco? What was my spell checker thinking... ok, here's the scoop.
There's another option that gets you essentially the same or better speed for half the price per gb:
http://www.sonnettech.com/product/tempossd.html
and
http://www.sonnettech.com/product/tempossdpro.html
These get you 6Gb/sec, full speed of the drives and when configured as raid up to 960mb/sec.
I suspect for our (multitrack, vi) purposes, JBOD will do anyway, and the Sonnet tech guys said if that's your choice the small card is all you need.
and
- ghobish
Just a heads up, I installed the 960GB card in a 2009 MacPro 4,1 and it was great as far as spped went but it was not long before it developed a problem that prevented booting from the card. It's been returned to OWC for warranty replacement; we will see what we will see.
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
San Francisco, Ca
FWIW (and you probably know this) but in my 2008 MP I was told that the card had to be in the skit next to the graphics card to have the specified performance. Maybe not true in the later MPs. Then again, at least worth mentioning.
Stay dry this week.
Stay dry this week.
- ghobish
I think that's where I had it. Plus it worked fine for a month or so. I also had a 480gb standard SATA-3 SSD of theirs completely die (stopped showing up on the bus) after a few months (a different client). Fortunately I had redundant backups in both cases. But I'm a bit skittish on relying on SSDs at the moment. We'll see how the replacements play out.MIDI Life Crisis wrote:FWIW (and you probably know this) but in my 2008 MP I was told that the card had to be in the skit next to the graphics card to have the specified performance. Maybe not true in the later MPs. Then again, at least worth mentioning.
Stay dry this week.
Gary Hobish
San Francisco, Ca
San Francisco, Ca
I've had 2 OWC SSD's die on me in the past...so I decided to try a couple other trusted brands, and I've not had any issues since. Not sure if I just got unlucky with the OWC ones, or whether I was on the 'bleeding edge' of tech, but between that and a couple of other sour experiences with OWC gear flaking out on me, I'm starting to see past the "OWC quality" marketing machine, and looking to other brands when I can. For SSD's, I've had a very good track record with Intel, Samsung and Sandisk, though I'll probably stick with Intel in the future due to their 5-year warranties (vs the normal 3 yr). When they work, SSDs are just about the best upgrade that you can put in a computer in terms of the before/after feel. Just make sure to have a reliable system in place to backup your data...ghobish wrote:I think that's where I had it. Plus it worked fine for a month or so. I also had a 480gb standard SATA-3 SSD of theirs completely die (stopped showing up on the bus) after a few months (a different client). Fortunately I had redundant backups in both cases. But I'm a bit skittish on relying on SSDs at the moment. We'll see how the replacements play out.MIDI Life Crisis wrote:FWIW (and you probably know this) but in my 2008 MP I was told that the card had to be in the skit next to the graphics card to have the specified performance. Maybe not true in the later MPs. Then again, at least worth mentioning.
Stay dry this week.
iMac 2017 4.2 i7, 32 GB RAM, Mac OS 10.12.6
DP 9.52
Motu 896mk3 hybrid, True Systems Precision 8, Apogee Rosetta 800
DP 9.52
- cbergm7210
Kinda scary stuff. If it wasn't for the owner of LASS and his cronies recommending this particular OWC product I'd have looked elsewhere.tonomud wrote:I've had 2 OWC SSD's die on me in the past...so I decided to try a couple other trusted brands, and I've not had any issues since. Not sure if I just got unlucky with the OWC ones, or whether I was on the 'bleeding edge' of tech, but between that and a couple of other sour experiences with OWC gear flaking out on me, I'm starting to see past the "OWC quality" marketing machine, and looking to other brands when I can. For SSD's, I've had a very good track record with Intel, Samsung and Sandisk, though I'll probably stick with Intel in the future due to their 5-year warranties (vs the normal 3 yr). When they work, SSDs are just about the best upgrade that you can put in a computer in terms of the before/after feel. Just make sure to have a reliable system in place to backup your data...ghobish wrote:I think that's where I had it. Plus it worked fine for a month or so. I also had a 480gb standard SATA-3 SSD of theirs completely die (stopped showing up on the bus) after a few months (a different client). Fortunately I had redundant backups in both cases. But I'm a bit skittish on relying on SSDs at the moment. We'll see how the replacements play out.MIDI Life Crisis wrote:FWIW (and you probably know this) but in my 2008 MP I was told that the card had to be in the skit next to the graphics card to have the specified performance. Maybe not true in the later MPs. Then again, at least worth mentioning.
Stay dry this week.
3 OWC SSDs fine here, including 1 boot, 2 samples.
Frank Ferrucci
http://www.ferruccimusic.com
- bralston
Now…that is not a very nice thing to say. Andrew and his Audiobro team are probably amongst the most ethical, technically talented and upstanding people I know in Los Angeles.cbergm7210 wrote: Kinda scary stuff. If it wasn't for the owner of LASS and his cronies recommending this particular OWC product I'd have looked elsewhere.
Regards,
Brian Ralston
Brian Ralston
- cbergm7210
Please excuse my miscommunication, brother. This was in no way derogatory toward Andrew. Indeed, because of my respect for the LASS team I purchased the drives and will continue to do so regardless of failure reports from folks on this forum regarding OWC drives.bralston wrote:Now…that is not a very nice thing to say. Andrew and his Audiobro team are probably amongst the most ethical, technically talented and upstanding people I know in Los Angeles.cbergm7210 wrote: Kinda scary stuff. If it wasn't for the owner of LASS and his cronies recommending this particular OWC product I'd have looked elsewhere.
- Bennie Sims
I finally was able to install the Crucial SSD M500 on my Mac pro!! Took forever for the Mac to recognize the hard drive no matter how much support I got from Crucial Tech support. Quite the process, but through true diligence and research I figured it out!! Now that it is working I absolutely love the feel of this new computer. That's what it feels like a new computer!! When I get the money I plan on changing all my drives!!!
Mac Pro Six Core Trashcan OX.10.13.3,Macbook Pro 2.53 GHz Intel Core i5 OSX 10.11,DP 8.07 and 9.52,Protools 2018.4 and 10.3.9,Logic 10.4.1.,Reason 8,Waves V9.7. Diamond Bundle, Mach Five 3.2.1, Vir 2, Kontakt 5.3, Melodyne Studio 3.2.2.2, Melodyne Single Track, Motu 2804 MK3, Apollo 8 Quad,Apollo 8 Duo,UAD 2 FireWire Quad Satellite, UAD Thunderbolt Quad Satellite, Rosetta 800, Avalon Vt 747sp, Focusrite 4x Red One, UAD 4-710d, Raven MTi 2 3.3.1, Motu MIDI Express XT.
Care to share your solution?Bennie Sims wrote:I finally was able to install the Crucial SSD M500 on my Mac pro!! Took forever for the Mac to recognize the hard drive no matter how much support I got from Crucial Tech support. Quite the process, but through true diligence and research I figured it out!! Now that it is working I absolutely love the feel of this new computer. That's what it feels like a new computer!! When I get the money I plan on changing all my drives!!!
Frank Ferrucci
Frank Ferrucci
