SSD for VI's?
Re: SSD for VI's?
Curious here. To what extenet are folks loading multiple VIs on one drive? "Heavies" I use are Ivory, Altiverb, couple Slates and Trillian. Suggestions for SSD distribution? Thanks.
2017 iMac 4.2 i7, 40 GB RAM, 256 SSD, multiple SSDs hanging. OS X 10.4.4.
Re: SSD for VI's?
Here's another sub-question:
--Do you run your projects off an external drive or from the internal drive? I'm thinking of getting an external SSD for my VI's and an additional external SSD for the projects. The internal iMac drive would also be a SSD, but the projects, nor the VI's, would be stored on this drive. Thoughts?
DP 11, Mac Studio M2 Ultra, 128GB Memory, Sonoma 14.3.1
- cbergm7210
Re: SSD for VI's?
This is what the creator of LASS (Andrew) and his right hand man (Sebastian) use...it screams:
http://eshop.macsales.com/shop/SSD/PCIe ... lsior/RAID
http://www.rfjmusic.com
Re: SSD for VI's?
Plug and Play. Check the link I posted earlier... in comments there's a link to the LaCie product page from where one can access the user guide. This product is the Thunderbolt equivalent of the OWC product Chris mentions above.Tobor wrote:I'm a little fuzzy on how these Thunderbolt SSDs work....is an adaptor or some sort of host frame needed, or are they plug and play?
I'm running four SATA2-connected SSDs in my Mac Pro... one system, one project/data, and two sample streaming, but you could run a large project, including VIs, from a single SSD if it is PCI-based.
HC Markus
Re: SSD for VI's?
What's the size of each of your SSD's?HCMarkus wrote: I'm running four SATA2-connected SSDs in my Mac Pro... one system, one project/data, and two sample streaming, but you could run a large project, including VIs, from a single SSD if it is PCI-based.
Re: SSD for VI's?
System: 120
Project: 120
VI: 2x240
Project: 120
VI: 2x240
