Reaktor Razor Vocoder Setup in DP
Anyone here know how to setup Reaktor's Razor vocoder inside of Digital Performer?
DP is not included in the Razor manual for specific DAW setups.
I'm not sure if it entails using the 'Reaktor FX' plugin option in addition to the VI, or . . .?
Any help would be appreciated.
Cheers!
Cheers!
OSX 11.6.1, DP 11.02, Metric Halo ULN-2, Plug-Ins and stuff.
- thracks
Re: Reaktor Razor Vocoder Setup in DP
I don't have Razor specifically, but any time I wanted to process audio thru an AU, Reaktor or otherwise, I use the "FX" version.
Steve
2020 Mac Mini | Ventura | 828x |
Figured it out.
In case anyone else needs to know . . .
Use the 'Reaktor FX' plug-in on an audio channel. Route the modulator audio into it via a bus, or place the modulator audio file in that track. Create a MIDI channel and assign it to the 'Reaktor FX' plug-in to control the carrier pitch.
I have this setup working successfully in DP 8.0.6. When I bounce to disk, the whole vocoder chain doesn't record, although I hear it all thru the main outputs in DP when I play the sequence. Anyone explain?
iMac 2019, 40 GB RAM
MacBook Pro, 16GB, OSX 10.11
DP10, Studio One, PT, Logic X, Sibelius, Live, Reason
Apogee Duet, Apogee Ensemble
Pretty sure you have to record the output in realtime on account of the MIDI routing into the effect. The Finger, another Reaktor ensemble, is the same way.
MacPro 12core 64GB Ram 4 1TB SSDs motu 828mk3 DP 10.11
Yes you are correct, so I discovered. It is working for me now.Saintmatthew wrote:Pretty sure you have to record the output in realtime on account of the MIDI routing into the effect. The Finger, another Reaktor ensemble, is the same way.
Sent from my iPad using Tapatalk HD
