Who use DP8 in surround situation ?
Aramis
Re: Who use DP8 in surround situation ?
Post by Aramis »
stephentayler wrote:I agree that the iPad solution is not great - Magic trackpad actually works better!
Stephen
Have you found a way to use the Magic Pad to move the puck ?
This would be the best way indeed !
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
Aramis
Post by Aramis »
Stephen
I wish MOTU would add an X and Y MIDI solution to that joystick one !!!!!!
stephentayler
Post by stephentayler »
I find it works if I position the pointer over the puck, then double-click and hold.
Maybe it's the way I have the trackpad set up - I don't use it much to be honest, I generally prefer the Magic Mouse, but this is great.
best solution yet!
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Aramis
Post by Aramis »
BKK-OZ wrote:
Aramis wrote:Did you try Hear ?
No. I bought it almost the same day that DP8 arrived.
Decided, having just invested in upgrading my RAM (32Gb), to make the jump to 64bit right then and there.
I thought Hear was 64 bit, alas, it is not.
:oops:
I don't want to go back and forth between 32-64bit, so I will have to wait until they finish updating to 64 bit. I wrote them, they kindly got back to me, saying "...soon...".
I have installed Hear demo and I cannot find the way to send 5.1 busses to its input to test it
:banghead:
stephentayler
I've used hEar - let me just remind myself how to set it up and I'll get back to you
stephentayler
I've given up trying with HEar for the moment - very frustrating.
I can't get the AU version to validate in DP8 (32) without crashing.
I can load the bridged VST version in DP (64) but cannot set the inputs to anything but stereo. Hmmm.
I recently used it in DP 7.24, and it worked fine. I could set the inputs to 5.1, but it would not allow me to output to stereo - only a surround bundle, so I had to create a stereo buss with the same LR outputs as a surround buss in order to record a stereo file. I can't remember how that worked in the past - maybe it was the same - I haven't used it much. (I suppose in order to bypass the plugin it still needs to be routed through to a surround bundle......)
Anyway it was quite good! It doesn't seem to give much of an impression of a front channel, but the illusion of the surround channels is quite convincing. I don't know how it seems for music, but I have used it on some ambient sound fields for some experimental/presentation work, for which it was most successful.
Let's hope they get this updated soon - it's always been problematic and caused potential conflicts.
Cheers!
Stephen
stephentayler
Aramis wrote: I have installed Hear demo and I cannot find the way to send 5.1 busses to its input to test it
:banghead:
If you have managed to get it to load, try setting the outputs to a surround bundle first, and see if that permits a surround input.
Cheers
Stephen
Aramis
Post by Aramis »
:banghead:
Cheers
Stephen
Hello Stephen,
I am still using 7.24 because my plan is to buy the next 27 inch iMac as soon as it is available.
Now, I can load Hear and I have created a surround track (5.1).
But, I do see only stereo input .......
:banghead:
stephentayler
Load your surround audio file - create a surround buss in Bundles for this channel - then create an aux channel - insert HEar - set this aux channel to your surround output - then see if the surround buss shows up on the input -
See if that helps
Stephen
Aramis
Post by Aramis »
stephentayler wrote:I find it works if I position the pointer over the puck, then double-click and hold.
best solution yet!
Stephen
Hey Stephen , I am trying to use my Magic pad again to control my puck in surround and something is buggy!!!! Sometimes I got the puck to follow my finger and I cannot get it back to follow it all the time .
Any clue to help me ?
Aramis
