Solo an Aux Tack/Channel?
FutureLegends
Post by FutureLegends »
Is it possible to solo an aux track?
Quite often I find myself wanting to hear just what's going on in an aux tarck/channel. But it has no solo button. Usually soloing whatever is going into the aux track works fine. But some times the things going to the aux are not next to each other or hidden from view etc etc.
Or right now, I've made and aux track for the backing vocals, but the meter for the aux is showing activity even when there's no backing vocals and when all the backing vocald are muted... but I don't know what the hell is going in there... And with no way (or is there a way?) to solo the aux, finding out what the hells going will be so much harder...
I've requested this feature... hope it's in DP8 ;)
Cheers
DZ
NazRat
Re: Solo an Aux Tack/Channel?
Post by NazRat »
From a previous thread:
NazRat wrote:
jbyerly1 wrote:+1 on wishing there was a solo button for Aux tracks
There is a solo button on Aux tracks. You uncheck Solo Exempt in the drop-down selection at the bottom of the track in the mixing board.
(or click in the Exempt column in the tracks overview)
DP8.06 PT11.2.0 VEP 5.3.x
stephentayler
Post by stephentayler »
This is difficult.
DP, like most consoles, has a solo-in-place system. When selected, solo cuts all other channels except the ones that have been exempt. But to solo only an aux return is impossible because it mutes all the other channels and their sends to the aux in question.
What we want to hear is just what is going through that aux channel
On an analog console there is usually a facility for pfl (prefade listen) which is usually available on aux returns as well as all the other channels. This allows one to listen to reverb returns, etc.
It is a completely independent circuit.
I don't think I have come across this in a DAW, correct me if I am wrong!
I'm thinking the simple way to achieve this might be to add a send to the aux and route that to an exclusive output, say headphones independent of the main monitor buss. Or if you have a monitor controller with alternative inputs you could patch it there.
Still thinking!
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
FutureLegends
Problem is, if I hit solo on the aux track, then it mutes the tracks that are sent to that aux track and I can't here anything.
I think aux tracks need a special solo that just let's you hear what's going through that aux...
FutureLegends
In my current project I had accidentally sent the slap of the upright bass to the back vox aux instead of to the bass aux. if I had been able to just solo the aux I would have saved considerable time finding that out... I eventually had to solo on track at the time to find out what was happening as going through the I/O setting and every send takes time and its easy to miss with DPs tiny fonts...
crduval
Post by crduval »
If you set your send to Pre fader, then disable solo exemption on your aux track, you can hear just the aux. This is what I do, even if I ultimately make the send post-fader - it's only one mouse click to change that!
If you turn off Solo Exempt, you can solo an Aux track.
Dan Worley
Post by Dan Worley »
Shooshie wrote:If you turn off Solo Exempt, you can solo an Aux track.
Come on, Shoosh, try to keep up. We're all kinda tired of carrying you or waiting around for you to catch up.
:wink: :)
DP10.13
FutureLegends
But what if that which is going to the aux track is not coming from a send?
Let's say I have the outputs of all backing vocal tracks set to the back vox bus that then goes to an aux track. It would be very convenient to just hit solo on the aux track to hear just what's going to that aux instead of hitting solo on all the individual tracks.
And in the case of a wrong routing like I had done, I would just have had to hit solo on the aux and I would have known what the error was.
If it's not in DP8 that's on my wish list for DP9! ;)
:wink: :)
Well, in the morning I often open all the existing new posts. Then as the day goes on, I answer them as I can get to them, when I take a break from other things. They just sit in the background until I get to them. Meanwhile, other people also answer the questions, but unless I remember to refresh the page, I won't see those. So I answer the question, only to find out later that my reply is way down the list, and that I've missed all the discussion in between.
Such is life. A day late and a dollar short. :?
Shoosh
crduval
Post by crduval »
Hi Future, I get your dilemma now. I don't know a quick way around soloing the aux in that case - wish I did!
Dan Worley
FutureLegends wrote:But what if that which is going to the aux track is not coming from a send?
First, make sure the Aux is NOT Solo-exempt.
Select the Aux, and all the tracks that are bussed to it, and group only the Solo (and color, if you like).
Now when you hit solo on the Aux, or any of the tracks in that group, all the tracks in that group will be soloed.
If you ask, "But now how can I hear one of the individual tracks in that group soloed?" Answer: Solo any track in the group and then hit Command-Option-Control-G to suspend track grouping, then unsolo the tracks you don't want to hear, always keeping the Aux soloed.
DP10.13
crduval
Post by crduval »
Then select all the individual tracks bussed to the Aux, and the Aux track, and group only the Solo (and color, if you like).
Now when you hit solo on the Aux or any of the tracks in that group, all the tracks in that group will be soloed.
Dan, thank you, I forgot you could group solos! Nice solution!
jbyerly1
Post by jbyerly1 »
Learn something new every day
Thanks for the tip Dan. That need to go on the tip sheet forum
Mac Pro 4,1, OS 10.9.5, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.07, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
Dan Worley
No problem. Glad to help.
DP10.13
