It is currently Sat May 18, 2013 9:37 pm
Text Size
put VI in to VRack ≠ MIDI Freeze? (SOLVED)
Postby williemyers » Sat Aug 04, 2012 1:33 pm
h'lo all,
I'm trying to do what's described on DP7, pg.194, "You can also freeze VI MIDI tracks, along w/their corresponding instrument track. Select both tracks, choose Freeze Selected Tracks....." but here's where things fall apart for me? In this case,m I have already put the VI in to a VRack and therefore it (the VI) no longer shows up in the tracks window, and therefore I cannot select both the MIDI track and the VI track, and therefore, I get no "Freeze Selected Tracks" option in the Audio menu....
hmmm.....???
Am I doing something wrong, or anyone know a workaround?
thanks
DigiPerf 8.01, PTools 10.3.5, Sib. 6.2,
OS 10.8.3/10.6.8, Mac Pro 2.8 8 core, 16 Gig RAM, 4 x >120G hds, 2 x 25" LCDs
Kurz Midiboard, MOTU MTP AV
~me
williemyers
Re: put VI in to VRack ≠ MIDI Freeze?
Postby NazRat » Sat Aug 04, 2012 2:15 pm
DP8.02 PT10.3.5 VEP 5.1 828mk3 ADA8000 MTP-AV
Mac Mini Quad 10.8.2
HP 7430s Quad Win8
NazRat
Re: put VI in to VRack ≠ MIDI Freeze? (SOLVED)
Postby williemyers » Sat Aug 04, 2012 3:24 pm
ah-freakin'-HA!!!
great answer! and many thanks for linking me to it!
the irony is that, when I couldn't freeze the MIDI track & the VR-ed VI yesterday, I actually did exactly what they described, then ran the Aux to a new channel & recorded the output! same result! but it didn't occur to me that I could've frozen the MIDI & the aux....now I'll know!
again, many thanks
~me
williemyers
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: kshrieve and 1 guest
Who is online
In total there are 2 users online :: 1 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
