MOTUNATION Main Forums
Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Live Kick Drum replacement
by zandurian » Tue Jul 17, 2012 5:45 pm
So, what's the favorite techniques around here?
Mac Pro 4,1 (early 2009) 2 x 2.26 GHz Quad-Core Intel Xeon 12 gigs RAM, OS 10.8.3, DP8.03, UAD2e, Superior drummer 2, Mach 5-2,Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2.1.0, Izotope RX
- zandurian
by daveyboy » Tue Jul 17, 2012 7:09 pm
www.dbwproductions.com
www.myspace.com/dbwproductions
8 core 2.8 mac pro w/ 10 gigs ram, DP7.24, Logic9.1.8 and PT 10.3, Apogee Symphony, UAD2, tons of plugs and VIs, OSX.8.3, 4 room commercial studio great for producers and composers!
Re: Live Kick Drum replacement
by zandurian » Wed Jul 18, 2012 1:56 am
daveyboy wrote:It's called aptrigga, http://www.apulsoft.ch/aptrigga/ and I have it and it works great. Well, I haven't tried it in the latest version of DP and lion but, it used to work great. I'm sure you're hip to the more expensive alternatives (slate trigger and drumagogg). Probably over kill. If you have access to logic, logic will analyze the track and spit out a MIDI file. Then you can go to town and trigger what ever you want and have it sync.
Thanks for the info db. Will prob start with aptrigga. I do have a copy of logic on my computer so may try that too. It's SO hard for me to get around in other DAWS though
- zandurian
by Tesionman » Wed Jul 18, 2012 2:28 am
Works really well and is often used with Metal music in live settings so the kick can cut through all the guitars etc....
cheers
Macbook Black | DP 7.24/8.02 | Motu 8Pre (x2) | M-Audio Fast Track Pro
Yamaha/Premier Drums
Sabian Cymbals
Pro-Mark Sticks
Tesionman - Posts: 194
by stephentayler » Wed Jul 18, 2012 3:24 am
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mac Pro 8 Core 2.8Ghz 16Gb RAM, MacBook Pro, 2Gb RAM, OSX 10.8.2, DP 8.01, PT9.06, Logic 9.1.8, MOTU Traveler, Ultralite Mk 3 Hybrid, MC MIx, MOTU VIs, Waves, Izotope Everything, Spectrasonics, SoundToys, Slate, Softube, NI Vintage Compressors, spl Surround Monitor Controller, spl Auditor Headphone amp, Genelec 1031A, 1029 5.1 system, Sontronics Mics, iPad etc..
stephentayler - Posts: 2275
by David Polich » Wed Jul 18, 2012 10:05 am
stephentayler wrote:If you have any Drum VIs or samplers, then MOTU's own Trigger Plugin does a decent job if you are prepared to do a little editing/tweaking of the MIDI... record it to a MIDI track and then fine tune the hits, remove unwanted triggers etc......
Cheers
Stephen
I was just about to point this out but Stephen beat me to it. Yes, DP
has a plug-in called "Trigger" which works fairly well.
I use Melodyne to process the audio on a drum track, and then Melodyne can
create a MIDI file from that which I then import back into DP. The advantage of this is that the Melodyne MIDI track is dead-on with the audio.
You still have to go to the MIDI track and set the notes to C1 (or whatever MIDI note you will use to trigger the new sampled kick) and if the original
audio track was recorded at a very low level, you'll need to select all the notes in the MIDI track and use "scale velocity" in DP to "beef them up".
http://www.davepolich.com
- David Polich
by zandurian » Wed Jul 18, 2012 11:39 pm
I recently acquired melodyne and haven't realized that feature. Will it put the MIDI directly to DP when being used as a DP plug-in?David Polich wrote:stephentayler wrote:If you have any Drum VIs or samplers, then MOTU's own Trigger Plugin does a decent job if you are prepared to do a little editing/tweaking of the MIDI... record it to a MIDI track and then fine tune the hits, remove unwanted triggers etc......
Cheers
Stephen
- zandurian
by zandurian » Wed Jul 18, 2012 11:50 pm
stephentayler wrote: record it to a MIDI track and then fine tune the hits"
Cheers
Stephen
I have used it in the past but and as to "fine tune the hits" it seems nuts in this day and age to have the MIDI not retain the exact right spot to trigger from - especially within one the premier MIDI programs of all time which also pioneered the merger of MIDI and digital recording. Yikes.
- zandurian
by stephentayler » Thu Jul 19, 2012 12:21 am
Cheers
Stephen
by frankf » Thu Jul 19, 2012 5:27 am
zandurian wrote:
[DP]...one the premier MIDI programs of all time which also pioneered the merger of MIDI and digital recording. Yikes.
Just points of information, and I'm not disagreeing with your use of "pioneering"
"In 1990, Opcode introduced StudioVision, which added digital audio recording (using Digidesign's digital audio hardware) to Vision's recording and editing platform. StudioVision was the first-ever commercially available product integrating MIDI sequencing and digital audio editing and recording on a personal computer"
"In 1990, MOTU added the ability to synchronise audio (digital audio) to Performer and released it as "Digital Performer," months after Opcode added this capability to Vision. Digital Performer was originally designed as a front-end to Digidesign's Audiomedia hard disk recording system, which later became Pro Tools."
(credit Wikipedia and my memory
Frank
Frank Ferrucci
DP 7.24
Mac Pro 3,1 OS 10.6.8
Metric Halo 2882, ULN-2
http://www.ferruccimusic.com
Mac Pro 3,1 24gb RAM DP8.03 OSX 10.8.3 MIO 2882d &ULN2d Firewire Audio Interfaces
by zandurian » Thu Jul 19, 2012 9:06 pm
stephentayler wrote:Well I didn't say MOTU Trigger was the best solution for doing this..... but it is included in DP so it's fine for some experimentation before shelling out for another piece of software. I mostly use other solutions such as apTrigga, and Slate Trigger.... but I nearly always have to do a lot of work on the audio track first... it all depends on the detection part of the trigger plugin.
Cheers
Stephen
Yes, and thanks for your response. Just had to rant a little about MOTU's oversight in not creating a rock solid trigger plug.
I understand the triggering threshold thing though - always takes some work. I usually gate the audio first to make sure I have a clean triggering track
- zandurian
by zandurian » Thu Jul 19, 2012 10:24 pm
Frank
Okay, so they are just a surviving co-pioneer.
- zandurian
by zandurian » Thu Jul 19, 2012 10:30 pm
I was triggering that way both live and from 2 inch tape in the 80's (and the Roland logo was involved then as well). I'm hoping for a little more sophistication now (on the pre-recorded triggering side) but I admit - it did "work".Tesionman wrote:Another way is triggering the kick drum live with a Roland/DDRUM kick trigger connected to a Drum Module which goes to a channel on recording device/FOH mixer. I use this along with a Mic and blend them. Works great.
cheers
- zandurian
by csiaudio » Fri Jul 20, 2012 9:34 am
iMac 2.5GHz Quad-Core Intel Core i5 -- OS 10.8.3 -- 12 Gigs Ram -- DP 8.03 -- Universal Audio Apollo -- UAD Satellite -- Neve Portico -- Eve SC207's w/Tannoy Sub
csiaudio - Posts: 419
- Location: Indiana; Where the corn is tall and the women are wide!
by David Polich » Sat Jul 21, 2012 9:08 am
zandurian wrote:I recently acquired melodyne and haven't realized that feature. Will it put the MIDI directly to DP when being used as a DP plug-in?David Polich wrote:stephentayler wrote:If you have any Drum VIs or samplers, then MOTU's own Trigger Plugin does a decent job if you are prepared to do a little editing/tweaking of the MIDI... record it to a MIDI track and then fine tune the hits, remove unwanted triggers etc......
Cheers
Stephen
No. When you select "Save as MIDI", you get a dialog box asking where you
want to save the file...I usually save it to the DP project folder, then
reimport it into the Chunks window (by simple dragging). Then I open it,
copy the MIDI track, return to the main sequence, and paste it to the main sequence.
- David Polich
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: Bing [Bot], cbergm7210, jloeb, wvandyck and 5 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
