Can I route external audio INTO Kontakt DIRECTLY
- toodamnhip
This forum is always great for a little help. I have looked online for this everywhere and cannot find it.
I wish to use Kontakt 5’s convolution reverb on a vocal track in DP.
Therefore, i would like to somehow route either directly or through an aux send, audio DIRECTLY INTO kontakt, and thereafter use it’s convolution reverb as a reverb for the vocal.
Cool idea eh? Impossible?
I already know I can load the whole vocal into Kontakt as an audio file and trigger it. But this means I would have to always run the tune through from start to finish. Impossible to mix that way.
So, I need to find a way to get external audio into kontakt in realtime, directly.
Any help or ideas would be appreciated.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- Prime Mover
Re: Can I route external audio INTO Kontakt DIRECTLY
Not sure, but another idea: why don't you just dig around and find the Kontakt IR in question, and plug it into ProVerb? The one nice thing about convolution reverbs, as apposed to synthetic delayline reverbs, is that it's possible to share the spacial design between different plugins. Altiverb's aren't compatible, I know, as are EWQLs but I was under the impression that most of the others just use WAV and AIFF files, I know ProVerb does, anyway.
I've never tried, because I've never been too impressed by Kontakt's reverbs... then again, I only have vers 4, maybe they've updated the reverb for K5.
— Eric Barker
Eel House
Eel House
- toodamnhip
Well I have new verbs from LA Scoring Strings, and they are pretty sweet. I might try that, though I am skeptical.Prime Mover wrote:Not sure, but another idea: why don't you just dig around and find the Kontakt IR in question, and plug it into ProVerb? The one nice thing about convolution reverbs, as apposed to synthetic delayline reverbs, is that it's possible to share the spacial design between different plugins. Altiverb's aren't compatible, I know, as are EWQLs but I was under the impression that most of the others just use WAV and AIFF files, I know ProVerb does, anyway.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Notice that you've got Guitar Rig. There's a convo reverb in Guitar Rig 4, would that be the same reverb that's in Kontakt?
I've been using Space Echo in Guitar Rig on an Aux, works great. Might be one way to access the NI Convo Reverb although you would have to upgrade Guitar Rig to 4 or 5 if you haven't yet.
Just a thought.....
Just a thought.....
If you select the Guitar Rig FX plug, you have access to the Reflektor convo reverb. You can include the Kontakt IRs from the NI Application support folder, but not all of them translate - specifically the first three groups of presets - Digital Reverbs and Real Plates are in this group. Not sure why and I haven't tried moving stuff around to see if it changes anything, but those two are the ones I'm after.
DP8.06 PT11.2.0 VEP 5.3.x
OK - looked further into it and Guitar Rig and Kontakt use different file IR formats for the convolution reverb (grir vs. .nk* plus patch files). The reason some of the Kontakt IRs work in Guitar Rig is that they are just WAV files. Don't have any clue as to how they determined which are protected/proprietary and which aren't, but the Digital and Real Plates are protected (and from what I can gather are in what NI calls a monolith file). So unfortunately no Lexicon or EMT stuff outside of Kontakt.
Anyway, I can understand why they would want to protect the IRs, but would have hoped that they'd have better compatibility between their own products.
Hmm - any reason not to use DP's ProVerb, on an aux track, and buss sends
from your audio tracks to that?
The reason I ask this is that I have done quite a bit of comparisons with
Kontakt's convo reverb and Pro Verb and...seriously, they're about the
same quality, with Pro Verb having a slight edge, IMO.
http://www.davepolich.com
- Prime Mover
Yeah, especially with some custom IRs like the SampleCity Bricasti M7 set, it's hard to imagine that Kontakt Konvolution (see what I did there?) will outperform Proverb. For instance, I love Alicia's Keys as a piano VI, but its reverb is pretty mediocre, and that's Scarbee. Even with a good IR, the units themselves give the user very little control.
— Eric Barker
Eel House
Eel House
- toodamnhip
I have many expansion libraries with their own proprietary reverbs such as LA scoring strings. Thus, I want access to all the reverbs available inside Kontakt.David Polich wrote:Hmm - any reason not to use DP's ProVerb, on an aux track, and buss sends
I do use proverb but I am impressed with the convo verbs from libraries like LASS and the sheer amount of options
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
