Board index
MOTUNATION Main Forums
Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Neat trick for opening and comparing 2 sequences (old tip?)
by mhschmieder » Mon Feb 13, 2012 12:26 am
My apologies if this has been documented previously in a tips section or a discussion, but surely I'm not the only person who didn't know about this DP feature (whether it is new or old):
If you have a sequence selected in a project in Tracks View, and go to the Chunks window, double-clicking on a different chunk will bring up that sequence in Tracks View in a new panel atop the other sequence/chunk.
That is as far as it goes; clicking in either panel on another tab effectively brings you back to single sequence/chunk mode, with multiple views on the same sequence/chunk.
But no matter; being able to load two chunks atop each other in Tracks View is EXTREMELY useful for comparing and copying track layouts and/or even copying cues, MIDI, etc. between chunks with everything neatly lined up visually.
MacPro Quad-Core Intel Xeon (2.8 GHz, 16 GB), OSX 10.6.8, MOTU DP 8.0.4, BIAS Peak Pro 7.0.1, DSP-Quattro 4.2.2, iZotope RX 2.1.0, Melodyne 3.2.2.2
RME FireFace UFX, Focusrite OctoPre Mk II, True Precision 8, AEA RPQ, Radial PZ-DI, Radial Reamp JCR
Eugenio Upright, Dingwall Afterburner, Yamaha BB-1025X, 60th Ann P-Bass, Fender Select J-Bass, Schecter Ultra Bass, Gretsch Jet Baritone
Yamaha WX5, Hammond 44 Melodion, Hammond XK-3c, Minimoog Voyager, DSI Prophet '08, DSI Evolver
mhschmieder - Posts: 7950
Re: Neat trick for opening and comparing 2 sequences (old ti
by Armageddon » Mon Feb 13, 2012 6:01 am
This is actually a small thing, but it's something that always frustrated me about DP. Every other DAW or sequencer I've ever used (and why I'm used to working this way), you've always been able to open multiple sequences simultaneously. Obviously, in DP, you arbitrarily close out a sequence when opening a new one. Why would you even need to do that, you ask? Well, in my case, it's usually because I need to copy a MIDI track, sometimes, even multiple MIDI tracks from one sequence (or DP project, if you will) to another. You can kind of do that by opening the original project, copying the track, closing it out, opening the destination project, create a new MIDI track and pasting the contents of the original MIDI track you copied into it, but it would definitely be easier to just have both sequences open simultaneously. Never even thought about the Chunks scenario. Just goes to show you, everything you want to do in DP is probably there, it's just not always obvious.
2008 Black MacBook Core 2 Duo 2.4 GHz/4 GB RAM/500 GB-7200 rpm internal drive • OS X 10.6.8 • DP 7.24 • Wave Editor 1.5.6 • TC Konnekt 24D • Korg K61 • Armageddon Music/Love's Young Nightmare on Myspace • My DP Projects on last.fm • IMDb Page • Facebook
- Armageddon
by Tobor » Mon Feb 13, 2012 7:40 am
And you probably know that if you want to toggle between sequences without having to load them you can just select the other sequence from the window top left of the TO window and the other windows. Almost the same thing when wanting to compare or copy MIDI data, etc.
iMac 2.7 i5, DP 7.24, 10.6.8, 828, MTPAV, Ivory, Spectrasonics, BFD2, Drumcore, Reason 6.5, Live 8, Logic 9, Miroslav, Waves, IK ST&TRks, S80, Triton, Axiom 49.
Tobor - Posts: 469
by philbrown » Tue Feb 14, 2012 7:25 am
Just be sure to keep track of which Chunk you have play-enabled! That one has gotten me a couple of times.
Main DAW: Mac Pro 2x2.26 Quad-core 6GB RAM OS10.6.6•DP 7.22•UA Apollo•UAD-2 Octo•MTP2
VI computer: Mac Pro 2x2.66 Dual-Core 4Gb RAM OS10.5.8/Windows XP•PCIe424>2408•Microlite
G4 2x1.25 1.25GB RAM OS9.22/10.4.11/Windows XP•MOTU896
Plugs: UAD•Scuffham•Flux IRCAM•NI Komplete•Waves•Stectrasonics•Arturia•Soundtoys•Nomad factory•Camel Audio•PSP•Stillwell•Cytomic•Schwa•Modartt•Korg•AAS•Five12•GForce•Voxengo
The Oversouls
doctorvague (modular synth videos)
The Oversouls
philbrown - Posts: 1284
by stubbsonic » Tue Feb 14, 2012 11:55 am
You can also load chunks (with or without audio) from other projects into the current project using the LOAD... command from the file menu.
by mhschmieder » Fri Feb 17, 2012 2:29 pm
Yeah, but that's entirely unrelated. I use the Load feature all the time when combining standalone legacy sequences into multi-sequence projects, or when moving a sequence to another project after it gets repurposed (for instance, a "personal" composition that gets requisitioned for a soundtrack or a jingle or website audio).
Good tips all, though. Sometimes it's the little things that save us the most time in the studio.
• Page 1 of 1
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: No registered users and 4 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
