It is currently Tue May 21, 2013 1:46 pm
Text Size
VIDEO OF NAMM DP8 DEMO
Re: VIDEO OF NAMM DP8 DEMO
Postby zed » Thu Mar 15, 2012 8:37 am
I just started dating a woman who has a PC laptop instead of a Mac laptop, and it is the only shortcoming in the relationship, thus far.
Fortunately, neither does she have an iPhone or an iPad, so she doesn't bore me with her attention to her media while we are spending time together. I like that. I found someone in the world still willing to give me their full attention when we are together. That's priceless. I think I'll hang onto her, even though she's not a Mac girl.
MacPro 2.8 GHz 8-Core Intel Xeon | 14 GB RAM | OS 10.6.2 | DP 7.12 | MOTU 2408 mk3 | Mytek Digital ADC | MIDIsport 4x4
zed
Postby jbyerly1 » Sat Mar 17, 2012 9:54 am
I have a question in regards to DP8. Is there any opinion as to one should wait till the bugs get worked out before upgrading as in waiting to buy Macs New PC's. Or will everyone jump right in and hope the beta testing was successful and it is ready for Motunation
Mac Pro 4,1, OS 10.8.3, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.03, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
jbyerly1
Postby bayswater » Sat Mar 17, 2012 2:46 pm
Bugs won't be the issue for me. I'll be looking more closely at compatibility with the plugs-ins I use regularly.
You can bet that most here will move pretty quickly, and there will be the usual weeping, wailing, and gnashing of teeth.
If you already use V7, it will take some time to get everything set up the way you want it on V8, so there's no point in waiting.
iMac 27" i7 16G, DP 8.01 & OS 10.8.2, DP 7.24 & OS 10.6.8, MachFive 3.12, 828 Mk3, Micro Express
Dual 2.0G G5 PCI 2G, DP 7.24, OS 10.5.8, 2408 MKII, UAD-1
Postby malditoyanki » Sun May 13, 2012 12:28 pm
Finally got around to watching the demo...and wow. Looks tremendous, especially the video improvements for scoring to picture.
I'll wager full 64 bit and full Cocoa will mean better multi-core processing support as well. It's not exactly knocking my socks off at the moment. Even so, DP7 is so damn stable...will be like naked cliff diving when I install that upgrade...(where's the emoticon for that btw?)
Intel 6core 3.33 Ghz Westmere 48 gigs ram, MOTU micro lite, OS 10.8, DP 8.01, Apogee Symphony I/O, Dangerous D-box, Vienna Instruments/Ensemble Pro, PLAY, most WAVES v9 plugs, Soundtoys, ProTools 10, Kontakt 5, Omni, Stylus, Albino, Ivory
"DON'T fail me again, Admiral..."
malditoyanki
Postby corbo-billy » Sun May 13, 2012 1:44 pm
Casually, having to code the entire D.P.'s Plug-ins must be a hell of a job. :oops:
MacPro SNOW Leopard 10.6.8. D.P. 8.0.3 & Kontakt5.1 _ Fireface800 Universal UAD-2 Quad_ FilterBank2 Sherman &Gibson Explorer _ MIDI Express XT _ Virus C _ Adrenalinn & Voyager Moog _ UAD1e X 2 _ SpeakerPhone _ PEAK Pro 6.03 _ PolyEvolber Keyboard _
http://img13.imageshack.us/img13/7498/irontop9.png" onclick="window.open(this.href)
corbo-billy
Postby cowtothesky » Sun May 13, 2012 7:54 pm
If you are running DP7, I see no downside to getting DP8 right when it comes out. Can't you run both versions on the same machine? I will get DP8 and keep DP7 running until I am able to make the changeover. Or am I missing something here. Would installing DP8 have any affect on DP7?
Imac 2.8 GHz Intel quad Core i7, 16GB Ram, Mac OS 10.6.7, DP 7.24, Motu Ultralite MK3 Hybrid, VSL Instruments, VE Pro, Vienna Suite, Spectrasonics, Project SAM, Kontakt, Korg M3
cowtothesky
Postby MIDI Life Crisis » Sun May 13, 2012 8:24 pm
A lot depends on if they change the MAS Audio Unit file. That changed between DP 5 and 6 and if you installed 6 you couldn't use 5 unless you reverted to the DP 5 MAS file - that is assuming you had a copy saved before the install or reinstalled DP 5 to get the file back.
There was an added feature to the DP 6 MAS unit (can't remember what it was) but you lost that feature with the DP 5 file, and DP 6 worked OK sans the extra feature. Major PITA, so if you are not doing backups of your OS libraries, that might be an issue.
Unless DP 8 is a dog (which I doubt it will be) then there is no reason to revert to DP 7, IMO.
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.3 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
Postby mikehalloran » Mon May 14, 2012 3:01 pm
MIDI Life Crisis wrote:A lot depends on if they change the MAS Audio Unit file. That changed between DP 5 and 6 and if you installed 6 you couldn't use 5 unless you reverted to the DP 5 MAS file - that is assuming you had a copy saved before the install or reinstalled DP 5 to get the file back.
I am not sure I am following you - maybe I am. If I saved a DP file in 6, I could no longer open it in 5 - that is true.
For that reason, I duplicated my project folders and opened those in 6. It took me a short while to conclude that I didn't like 6. Fortunately, I am able to open the originals in 5.
I have opened 6 again in an attempt to solve a problem I am having with 7.24 not finding many sound files on Lion. 5.13, 6.03 open them fine in Lion and 7.12 opens them on my G4 running 10.4.11.
I have found a workaround but MOTU support has yet to figure out the problem. News as it happens...
July 2010 iMac 2.93G i7 Quad-core with OWC eSATA mod, 20G RAM, OS 10.8.3
828mkII FW; MIDI Timepiece AV with Intel upgrade chip
DP 8.01, 7.24 with IK, mda, NI, Stilwell/Schwa, Izotope & Antares plugs, MachV 3.1.4
LogicStudio 9.1.8, Finale 2011Cr.1, Encore 5.0.6 & 4.5.5, DSP Quatro 4, QuickTime Pro 7.6.6
Test machine: G4-733: OS 10.4.11 / OS 9.2; DP 5.13; Encore 4.5.5; other legacy apps
Postby MIDI Life Crisis » Mon May 14, 2012 3:07 pm
That has NOTHING to do with what I'm talking about. The MAS Audio Unit resides in the Audio Library. The DP6 version was incompatible with DP5. As I recall, hitting record in DP 5 while attempting to use the DP6 MAS AU resulted in a crash. You can search for the threads but since it's a theoretical problem at this point, it already has too much traction. We'll have to find some other ghost to chase.
Postby mikehalloran » Mon May 14, 2012 3:27 pm
MIDI Life Crisis wrote:That has NOTHING to do with what I'm talking about. The MAS Audio Unit resides in the Audio Library. The DP6 version was incompatible with DP5. As I recall, hitting record in DP 5 while attempting to use the DP6 MAS AU resulted in a crash. You can search for the threads but since it's a theoretical problem at this point, it already has too much traction. We'll have to find some other ghost to chase.
No problem. Since I was never affected by it, I'm happy not to go there. I recorded in 5.13 as recently as two weeks ago. 6 is still installed.
Postby MIDI Life Crisis » Mon May 14, 2012 3:33 pm
I was also in Leopard at the time which may have been an additional factor.
Postby nightwatch » Tue May 15, 2012 12:23 pm
Well I for one need DP8 NOW!. I have a major project due in a month. Right now it's getting completely bogged down in 32-bit DP7. I have 20GBs of RAM, and my DP/Kontakt project is using every last "bit" of the RAM.
I opened the project in Logic in 64-bit mode (with all of my 64-bit plugins, VIs and sample libs), and it made a huge difference.
The same project ran a heck of a lot smoother in Logic 64-bit than it did in DP 32-bit. It sucks when you have several instances of Kontakt's memory sever running and eating up 4GBs of RAM for each one. In Logic's 64-bit mode I was able to turn off Kontakt's memory sever! The addressing is so much better. It cut my RAM needs down quite a bit, and helped my CPU out.
I hope DP8 is very well optimized with it's CPU usage (with cocoa it probably will), because right now I'm pushing it to the limits. So MOTU, please hurry up!
Thank you
MacPro (2008) 8-core 3GHz, 32GB RAM, DP 8 64-bit, Logic 9, Peak, Waves 9, Kontakt 5, LASS, Cinematic Strings 2, CineBrass and CinePerc, WIVI Winds and Brass Pro Player, Project SAM Orch Brass Classic, Albion, Soniccouture, Piano In Blue, PianoTEQ, Emotional Piano, MetaSynth, Aurturia, Redwirez, Spaces, MOTU 896HD w/Black Lion mod, Vintech and Avedis hybrid pres, Bogner guitar amps, Eden bass amps, mics, mics, mics, and more...
nightwatch
Postby malditoyanki » Tue May 15, 2012 1:03 pm
Yeah I did a lot testing and found DP7 doesn't use processing power as well as we might like. I think it's fundamentally built on code from DP4 or maybe earlier. This full re-write should clear that up as far as I know. Looking forward to it myself very much!
malditoyanki
Postby Prime Mover » Tue May 15, 2012 1:16 pm
I highly doubt that there's any code from earlier than DP4, prior to that it was OS9 territory. But yeah, you're probably right, a lot of the basic code is likely from DP4. DP6 was the only major update from DP4 that we've seen so far, everything else has been small feature additions and service updates.
— Eric Barker
Prime Mover
Postby nightwatch » Tue May 15, 2012 11:11 pm
Yeah I agree. I was working on a single project for so long that I had to skip DP5 and DP6 - I went straight from DP4 - DP7 when the project was over and it seemed like they felt the same (DP4 and DP7).
After reading about whatever problems you guys had with DP6, it looks like I didn't miss much. I saw DP6... what an ugly interface that was. I like DP7's themes and DP8 looks to have even better looking themes. Can't wait!
nightwatch
PreviousNext
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: Bing [Bot], wvandyck and 5 guests
Who is online
In total there are 7 users online :: 2 registered, 0 hidden and 5 guests (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
