How to make new version the default to open new projects?
- Kellog
Like subject says, how do I make 7.2 the default version to open all projects, new or old (still have 7.12 on there just in case)? Did it when I updated to 7.12, but can't find it or remember now. Tried 'get info'... I can use 'open with' each time, but that feels like an extra step at startup. thanks!
Mac mini (2018) 3.2 Ghz 6 Core Intel Core i7 w/64 GB ram, OSX Catalina 10.15.7, DP 10.13, UAD Apollo Quad, Komplete 13 Ultimate, Superior Drummer 3, EZ Keys, EZ Bass, EZ Mix 2, Stylus RMX 1.7f, Avid Eleven Rack.
Re: How to make new version the default to open new projects
kellog, I'm a bit confused, but if I get what you're saying, new projects - one's started by double-clicking your DP (7.2) icon, are *not* opening up in 7.2, but rather 7.12? hmmm...wierd...Kellog wrote:Like subject says, how do I make 7.2 the default version to open all projects, new or old (still have 7.12 on there just in case)? Did it when I updated to 7.12, but can't find it or remember now. Tried 'get info'... I can use 'open with' each time, but that feels like an extra step at startup. thanks!
When you want to start a new DP project, are you double-clicking the DP 7.2 icon in your Apps folder or are you clicking a DP icon in your dock? If it's the later, your dock DP icon may still be referring back to the DP 7.12 in your apps folder. If that's the case, trash that dock icon and drag in a new one from the 7.2 app in Apps.
otherwise, as I said....confused?
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
- Kellog
Sorry for confusion. Yes I have 7.2 icon in dock and it does work. I was mostly asking for older files so they'd automatically open in 7.2 instead of 7.12. When I upgraded to 7.12, somwhere in the process it asked me if I wanted it to be the default to open all dp projects. That's my goal. thanks for reply
- buzzsmith
There's another recent thread on this, but my "workaround" is just to open the files from within DP 7.2.
With DP 7.2 open use File>Open...
Double clicking an existing file made in 7.12 will most likely open 7.12.
Hope that helps...
Buzzy
Hope that helps...
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- Kellog
thanks buzzsmith. FYI when I right click the dp file I want to open, I'm given the option to "open with" and all versions I have are there to choose from, so I can choose 7.2. As I said, it just feels like an extra step, and I'm sure 7.12 asked me somewhere if I wanted it to be my default for opening projects. Maybe I'm being silly...
- buzzsmith
Here's the other thread...
http://www.motunation.com/forum/viewtop ... =1&t=42593" onclick="window.open(this.href);return false;
Buzzy
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
The usual GET INFO thing isn't working here either. There is clearly something in the file TYPE in DP 7 files that is broken. Here's the strange part...
If I tell the FINDER to OPEN ALL similar files, it won't and the file reverts to 7.12, but if I DON'T select that option and simply dismiss the GET INFO box after selecting OPEN WITH, that file then opens with 7.2 from that point on. This only happens in DP. No other app appears to be affected.
Reported to MOTU via Techlink
MOTU?
[Also posted in http://www.motunation.com/forum/viewtop ... 64#p357764" onclick="window.open(this.href);return false; ]
MOTU?
- Kellog
I agree MIDI Life Crisis, something's askew in this version. Buzzy's link did show me to use the alt key after right clicking an 'older (7.12)' file. Then I can choose 'always open with', but it only affects that one file. Other 7.12 files are still defaulting to 7.12. I could right click them all one time each and fix 'em (gotta let them open tho, I believe), but now it just feels like a bug, which, therefore 'bugs' my curiosity... 7.12 became the default after that update. Haven't figured out how to make 7.2 the default.
I'm guessing it's a simple fix and not a big deal, but I've been wrong before... when was that? 1960 something... LOL!
here's a shot...if you're keeping that copy of 7.12 in your Apps folder..."just in case"..., drag it to the trash. Then all of your older DP sessions should - by default - open with the 7.2 app in your Apps folder. And they should - - as soon as you do a "Save" - - become 7.2-type files.Kellog wrote:Sorry for confusion. Yes I have 7.2 icon in dock and it does work. I was mostly asking for older files so they'd automatically open in 7.2 instead of 7.12. When I upgraded to 7.12, somwhere in the process it asked me if I wanted it to be the default to open all dp projects. That's my goal. thanks for reply
You can always put 7.12 back in Apps and use it if need be...just don't forget and empty your trash!
~me
~me
- Kellog
That may be the plan for now, thanks willie.
I know all of you are not using Snow Leopard, but I can't help but wonder if DP is not supporting creator codes any longer, because Apple is not supporting them either.
More info:
http://arstechnica.com/staff/fatbits/20 ... adness.ars" onclick="window.open(this.href);return false;
And a $5 workaround:
http://pagehand.com/launchcodes/" onclick="window.open(this.href);return false;
More info:
Safer than drag to Trash is to zip 7.12 using contextual menu and leave it in App folder, then delete original. You can always get it back if you really need it, but I ask why would you? 7.2 is solid.
Frank
Frank
Frank Ferrucci
http://www.ferruccimusic.com
