Bidule - One more thumbs up
cbergm7210
Post by cbergm7210 »
I just have to say (like many others) how great Bidule is.
I have been running DP every day for the last two months in tandem with Bidule, loading up Bidule with every VI and loading none in DP. What a smooth way to work. DP never crashes, Saves are instant (or short), everything is just nice. And if DP does crash for some reason, there's no waiting for the re-load of VI's when you boot DP back up.
Just wanted to throw some good vibes this way. :D
Chris
http://www.rfjmusic.com
Dan Worley
Re: Bidule - One more thumbs up
Post by Dan Worley »
Chris,
Is Bidule easy to set up? I've been wanting to try it but some of the examples I've read on how to set it up seem confusing and convoluted and I don't want to spend a lot of time being frustrated.
Thanks,
Dan Worley
DP10.13
newrigel
Post by newrigel »
You first say DP never crashes then you say when it does...
Good to hear your having success.
cbergm7210
Dan Worley wrote:Chris,
Thanks,
Dan Worley
Hey Dan,
It's not hard, but it's not the most straight forward thing, either. First, install the free Rewire part from Propellerhead:
http://www.propellerheads.se/download/updates_rewire/" onclick="window.open(this.href);return false;
(and install Bidule)
Then, open DP and make a MIDI track and an Aux track. For the Aux track Input, choose a Plogue Bidule Device input. After you do that, then launch Bidule and it should load in Rewire Mode. (If you don't choose an input for the Aux track first, Bidule won't load in Rewire mode) Then you just load your VI's into Bidule and configure the VI's MIDI in's to the Bidule Rewire module and the VI's audio out's to the Bidule Rewire output. Lastly, on your MIDI track in DP you choose the correct Bidule MIDI channel to play the VI and then when you play it, it's audio will come to your Aux track in DP.
If you use the Bidule Rewire MIDI module as the MIDI in to the VI's, automatic delay compensation kicks in. If you use a Bidule module under the MIDI Devices tab in Bidule, it works but with no delay compensation.
Also, you have to launch Bidule without DP running and go into Bidule's Preferences and set the check box under Rewire to Enable Rewire Mixer, and bump up your Rewire MIDI Ports and Channels if you want. I think that's all.
Here's a couple of rudimentary videos of setting it up:
http://www.youtube.com/watch?v=Sx-3W_FtV7Q" onclick="window.open(this.href);return false;
http://www.rfjmusic.com/bidule.mov" onclick="window.open(this.href);return false;
Go on Youtube.com and do a search of c0mp0ser, on one of our MOTUNATION members. He's got some videos as well.
Believe me, brother, it's worth the minor hassle of setting it up, and once you get used to loading VI's into it, you'll never go back. Kontakt 3.5 and 4.0 use a memory manager to load more than 4 gigs into a setup, which is awesome if you are using a big orchestral setup using a bunch of Kontakt VI's. I don't know if Kontakt's memory manager works when it is in DP, because I do not see it loading when I do use it inside of DP.
If you go for it and get hung up, give me a PM and we'll figure it out.
Chris
cbergm7210
newrigel wrote:You first say DP never crashes then you say when it does...
I did say that, didn't I? Never say never, eh? :shock:
Really, I've bogged down DP for the last three years with tons of VI's and it would crash more often than one would like, but it just doesn't crash (because of VI's :wink: ) running it this way.
Dan Worley
Thanks,
Dan Worley
Hey Dan,
Chris
You're awesome, brother. Thanks! I'm going to go for it later on today or this evening.
Much appreciated.
c-ya,
Dan Worley
DP10.13
I'm interested in trying this, too. I assume that the Standalone version, rather than the AU version is being used?
I'm really confused after looking over the Plogue site.
cbergm7210
cuttime wrote:I'm interested in trying this, too. I assume that the Standalone version, rather than the AU version is being used?
Yes, standalone with DP via Rewire.
What is your confusion regarding?
Buzzy
Post by Buzzy »
Will rewiring with Bidule allow simultaneous rewiring with Reason? Or is it a one or the other deal?
.Bzz...
Mac Pro 6 Core-10.14.6-32GB | DP 10 | 828mkII fw | Receptor 1&2 |Reason 10.2 | Goliath | EWQLSO Gold | QL RA | Voices of Passion | Ocean Way Drums Platinum | SSD-EX | Chris Hein Horns 1&2 | Komplete 12 | AAS - Ultra Analog | BS Accordions | Nomad Factory Integral Bundle | WaveArts Power Suite 5 | Izotope Music Production 3 | Variax 600| TD-8 Drums ||STUDIO››|| MacPro QuadCore-2.66-10.4.11-8GB | 828mk3 fw | 8Pre fw (X2)| MC Mix (X3) MC Control ||
cbergm7210
Buzzy wrote:Will rewiring with Bidule allow simultaneous rewiring with Reason? Or is it a one or the other deal?
Ah, good question. I do not use Reason or any other Rewire program with Bidule, so personally I cannot speak to that.
Anyone?
zed
Post by zed »
And perhaps the same "anyone" who knows the answer to that question can tell me if it is at all possible to use Reason Refills in DP without having to purchase Reason. I've been told you can use the Refills in DP using Bidule, but I don't really want to spend the additional $350 bucks on Reason. It gets pricey.
Dan Worley
Chris,
Got it going no problem thanks to your help. I loaded a ton of stuff into Bidule that would normally bog DP down, but DP is crusising along just fine. Very cool. This will make things much easier to organize and switching out instruments is a breeze.
I've been wanting to do this for quite some time but was a little chicken. Thanks for makin' me cross the road.
Now I just need to learn how to best utilize Bidule to get the most out of it.
Thanks again.
Dan Worley
DP10.13
zed
Post by zed »
Dan Worley wrote:Got it going no problem thanks to your help. I loaded a ton of stuff into Bidule that would normally bog DP down, but DP is crusising along just fine. Very cool. This will make things much easier to organize and switching out instruments is a breeze.
Wow! Less than 12 hours ago you were in the same position that I am now... wanting to pursue this Bidule thing but fearful of frustration.
I'm very glad to hear that it has gone well for you so far. I am now encouraged to proceed with this myself. :-)
Dan Worley
Go for it, Zed!!! Only one thing tripped me up at first: I needed to restart my Mac after installing Rewire before DP could see it.
Other than that it was a piece of cake.
The videos helped.
c-ya,
Dan Worley
DP10.13
cbergm7210
The videos helped.
c-ya,
Dan Worley
Great, Dan!
Yes, it is a game changer for sure. Simple but effective.
