Shifting MIDI Note Data
txa1265
Post by txa1265 »
Hi:
I am revisiting a bunch of old Performer songs I made back in the 90s (before standard MIDI was 'standard' :) )... and a lot of it was made using a drum machine that had its own ideas about what note values should be used.
Where I used loops things are simple ... but where I either 'performed' the drum track or used some of the 'humanize' or other features that filled up your event list, I now have a massive job editing several minutes of bass, snare, etc. to get it all correct.
I have tried searching but come up empty - is there a simple way to do a 'search & replace' in the event list?
And just to be clear, I am using DP 9.51 on a 11.6 MacBook Air.
Re: Shifting MIDI Note Data
Is it the note values you want to change? You can use the Transpose command window for that, and enter a map showing the current note values, and the values you want them to be. See V 9.5.1 manual p 554.
txa1265
Post by txa1265 »
bayswater wrote:Is it the note values you want to change? You can use the Transpose command window for that, and enter a map showing the current note values, and the values you want them to be. See V 9.5.1 manual p 554.
Perfect - should have thought of that ... great solution, thank you for the reply.
As I recall, you can save the map for future use, too?
wvandyck
Post by wvandyck »
James Steele wrote: As I recall, you can save the map for future use, too?
The custom Transpose map can be saved for future use.
philbrown
Post by philbrown »
Shooshie may chime in here, but there's also the search feature on page 511 that may help your cause.
It's always weird typing 'search' into a search bar that already says search.
