Track color change
Track color change
Is there a way to change the colors of a number of chosen tracks at one time? I'm talking about changing the color where the track title/name is in the sequence editor (which would carry over to the mixer & channel strip). I like to have groups of tracks the same color (brass one color, woodwinds another color, etc.) This would be done after the tracks are created. I can change them one at a time but haven't figured out how to do multiple tracks at one time (if that's even possible).
- FMiguelez
Re: Track color change
Select your desired tracks. While pressing letter "t", change the colour in one of them. Bam! Done!
Crashes DP9 when I do that. Found it under 'assign colors' in the setup menu.FMiguelez wrote:Select your desired tracks. While pressing letter "t", change the colour in one of them. Bam! Done!
Re: Track color change -DP 9 coming apart at the seams!
That's a new one. DP has never crashed for me when changing track colors. If someone is seeing a variety of crashes happening after a mouse click, that person may want to check their mouse driver for an update, reinstall that driver and DP and start off by repairing permissions.
Otherwise: BUG! BUG! MOTU MUST FACE!
- Robert Randolph
I just did the T+track colour thing this morning and no crash here.musicman691 wrote:Crashes DP9 when I do that. Found it under 'assign colors' in the setup menu.FMiguelez wrote:Select your desired tracks. While pressing letter "t", change the colour in one of them. Bam! Done!
Checked it on my laptop (which has now somehow developed the the insert automation bug), and it works fin there too.
I'd say there's something fishy going on...Robert Randolph wrote: Checked it on my laptop ... and it works fin there too.
This is the first time I've ever had a DP crash after a mouse click. DP actually crashed as I clicked on the color picker in a track. So I wouldn't call what happened to me a 'variety of crashes'.MIDI Life Crisis wrote:That's a new one. DP has never crashed for me when changing track colors. If someone is seeing a variety of crashes happening after a mouse click, that person may want to check their mouse driver for an update, reinstall that driver and DP and start off by repairing permissions.
DP does not crash when I use 'assign colors' from the setup menu. I think this is another one of those DP9 crashes that may happen to some but not others. Remember that I am using the DP9 download from MOTU and not the one on the dvd.
Working fine here as well.
It's just the 't' key with no modifier? Is there another color picker to work from and not just the one in each track in the sequence editor screen? I can't find anything on this shortcut procedure in the manual.Robert Randolph wrote: I just did the T+track colour thing this morning and no crash here.
- Robert Randolph
Hold T, no modifier, press the colour selector in the sequencer screen, select your colour, let go of T.musicman691 wrote:It's just the 't' key with no modifier? Is there another color picker to work from and not just the one in each track in the sequence editor screen? I can't find anything on this shortcut procedure in the manual.Robert Randolph wrote: I just did the T+track colour thing this morning and no crash here.
It is in the manual, but it's really tricky to find. It's on pg. 70 in the DP9 pdf manual.
I looked at page 70 of the DP9 pdf manual and it's not there; that page deals with audio files. Track colors don't come in until page 75 and even then I can't find it.Robert Randolph wrote:Hold T, no modifier, press the colour selector in the sequencer screen, select your colour, let go of T.musicman691 wrote:It's just the 't' key with no modifier? Is there another color picker to work from and not just the one in each track in the sequence editor screen? I can't find anything on this shortcut procedure in the manual.Robert Randolph wrote: I just did the T+track colour thing this morning and no crash here.
Page 116 deals with track colours. Page 170 shows the options for track group settings, including track colour. The manual rarely gets into explanations of using features in combination.
- Robert Randolph
I mistyped. The explanation of the W and T key is on page 170.musicman691 wrote:I looked at page 70 of the DP9 pdf manual and it's not there; that page deals with audio files. Track colors don't come in until page 75 and even then I can't find it.Robert Randolph wrote:Hold T, no modifier, press the colour selector in the sequencer screen, select your colour, let go of T.musicman691 wrote: It's just the 't' key with no modifier? Is there another color picker to work from and not just the one in each track in the sequence editor screen? I can't find anything on this shortcut procedure in the manual.
The W and T keys work for a lot of functions in the Sequence window.
Thanks for the info. So I have to use the Tracks screen to change color this way and not the sequence editor? I was using the se screen color picker to make the change and that's what was crashing DP. If that's the way it's supposed to work that's not too cool. Should be able to do the deed in both screens.bayswater wrote:Page 116 deals with track colours. Page 170 shows the options for track group settings, including track colour. The manual rarely gets into explanations of using features in combination.
No, it works in the Sequence Editor too. I'm just in the habit of doing all the track setup, routing etc in the TO, and using the Sequence Editor for arranging.musicman691 wrote:Thanks for the info. So I have to use the Tracks screen to change color this way and not the sequence editor? I was using the se screen color picker to make the change and that's what was crashing DP. If that's the way it's supposed to work that's not too cool. Should be able to do the deed in both screens.bayswater wrote:Page 116 deals with track colours. Page 170 shows the options for track group settings, including track colour. The manual rarely gets into explanations of using features in combination.
