OT? Soundflower, alternatives?
Re: OT? Soundflower, alternatives?
There was a note with Soundflower 2.02b that you had to run an uninstaller to get rid of the older version. And that Soundflower Bed software was not yet available for El Cap.
The 2012 version Soundflowerbed.app that came with 1.6.6b works just fine in El Cap. I tried it last night before posting the instruction link.stubbsonic wrote:There was a note with Soundflower 2.02b that you had to run an uninstaller to get rid of the older version. And that Soundflower Bed software was not yet available for El Cap.
I also ran the 1.6.6b uninstaller — which didn't work. Then the 2.0.2b installer and that did nothing for me either.
I imagine that I probably have to disable SIP to uninstall 1.6.6b. That's not going to happen just so that I can fiddle around with something that works perfectly in my system.
A I mentioned, I use QT 7.6.6 as the record device for Soundflower. I have it preset which saves time. Other than that, I follow the instructions and it works, monitoring and all.
1.6.6b probably does — I see no reason why it shouldn't. 1.5.1 for the PPC is also available still.Klaus wrote:Does it work also in 10.6.8 ?
Klaus
Not certain I need anything there but definitely interesting.labman wrote:Loopback. Tis stinkin' awesome!!! (Rogue Amoeba)
https://www.rogueamoeba.com/
It looks like a packaged version of Soundflower. Does it do more?labman wrote:Loopback. Tis stinkin' awesome!!! (Rogue Amoeba)
The .kext is 2.0b.2, Soundflower ( app ) is still 1.6.6, at least that's what I've read latelySMS wrote:I just downloaded and ran the 2.0b.2 installer. Haven't tested yet, but it looks like it will work, as it's now showing up i8n AM setup, DP, etc. Oddly, the installed version shows as 1.6.6 ?????
Best
Klaus
loopback is elegant and solid. Save sets for routing apps to one another (multiple apps at same time) . Personally I found sound flower less than solid. And Loopback feels seamless and I dont have outlook over my shoulder.
- guitardood
If it's your client's material on RN couldn't you just download the file through the account?SMS wrote:Need to get a Reverbnation file into DP for a client. I used Soundflower for this kind of stuff in the past but I can't get it to work anymore. Is there another or a better way to do this?
Spence
________________________________________________________________________
Best,
Guitardood
Chuck Fletcher on Reverb Nation
Chuck Fletcher on Facebook
"Life is like a box of chocolates. You know, eventually you're going to get the one filled with alien-like nasty tasting goo and have to spit it out and say YUCK".
Best,
Guitardood
- SMS
I didn't see a way to do that without a password or something, and didn't have time to wait for that.
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
Hmm. I thought Rogue Amoeba bought Soundflower and used it to create a number of products, this included.labman wrote:loopback is elegant and solid. Save sets for routing apps to one another (multiple apps at same time) . Personally I found sound flower less than solid. And Loopback feels seamless and I dont have outlook over my shoulder.
Seconding that it's working fine in El Capitan 10.11.4mikehalloran wrote:It looks like 2.0.2 is out and installs correctly in El Cap. I remember that I was running Yosemite when I installed 1.6.6b.
https://obsproject.com/forum/threads/so ... tan.37388/
I just used Mike's link in the quote.
DP 11, OS Ventura
http://www.cammillarmusic.com
I played with it a bit. Apparently I had the 1.6.7 SoundflowerSigned.kext in System/Library/Extensions and it works fine.
Since programmers aren't supposed to put files there anymore, I ran the uninstallers for 1.6.6b and 2.0.2b, then the installer for 2.0.2b. It installed Soundflower.kext 2.0.2 in Library/Extensions but did not remove 1.6.7. Ok…
I removed 1.6.7 manually and the 64 channel version was gone when I launched Soundflowerbed.app. Hmmm… I then re-ran the 2.0.2b installer and 64 channel was restored.
For kicks, I hid Sopundflowerbed.app in the trash and the 2.0.2 installer didn't put it back. Put the app back and it worked fine as before. So... if you want Soundflowerbed and it to work in El Cap, best to download and install both 1.6.6 and 2.0b2. You must disable Gatekeeper to install 1.6.6b unless you find that version with SoundflowerSigned.kext 1.6.7 (I cannot find it for download anymore).
Here are some links:
Download 2.0b2. for Intel Mac Yosemite/El Cap. 2.0b1 is there and has a 128 channel version that he removed for 2.0b2.
https://github.com/mattingalls/Soundflower/releases/
Previous versions up to the 1.6.6b beta includes PPC versions
https://code.google.com/archive/p/soundflower/downloads
Instructions to use and monitor sound.
http://www.sylvanadvantage.com/index.ph ... und-flower
I'm a JackOSX fan
