It is currently Thu Feb 22, 2018 5:08 pm
Text Size
GUI is only displaying the left side!!! HELP!!
Postby drdrawbar » Mon Apr 28, 2008 5:26 pm
I just bought this software and after hours of figuring out that i had to copy the samples to program files/motu/vst/sounds.....i have the sounds working, but only the left 3/4 of the GUI is displayed. Im running this on a PC with 4 gig of ram and 2.4 Ghz dual core.
drdrawbar
Re: GUI is only displaying the left side!!! HELP!!
Postby CWoodONe » Mon Apr 28, 2008 6:01 pm
drdrawbar wrote:I just bought this software and after hours of figuring out that i had to copy the samples to program files/motu/vst/sounds.....i have the sounds working, but only the left 3/4 of the GUI is displayed. Im running this on a PC with 4 gig of ram and 2.4 Ghz dual core.
What host are you using?
DP 5.1, Ableton Live 6 Beta, Cubase, Absynth 3, BFD, Ivory, Cameleon, Tassman, Dimension Pro, Rapture, Kontakt 2, Minimoog V, Reason 3, Reaktor 5, Mac Pro, Trigger Finger, Axiom 25, Axiom 49
CWoodONe
What host
Postby drdrawbar » Mon Apr 28, 2008 6:18 pm
Cubase primarily, but it does it as a standalone as well.
drdrawbar
Re: What host
Postby CWoodONe » Mon Apr 28, 2008 6:34 pm
drdrawbar wrote:Cubase primarily, but it does it as a standalone as well.
I have Cubase 4 on my PC, I'll see if it does the same thing for me...
CWoodONe
Thank You
Postby drdrawbar » Mon Apr 28, 2008 6:38 pm
I cant tell you how much i apreciate it. I have a tech note in to motu, but who knows how long that will take to get an answer.
drdrawbar
Re: Thank You
Postby CWoodONe » Mon Apr 28, 2008 7:10 pm
drdrawbar wrote:I cant tell you how much i apreciate it. I have a tech note in to motu, but who knows how long that will take to get an answer.
Yeah, the installation routine for the Mac was dead wrong, and my tech support form is still "unread"...
Trying right now.
CWoodONe
Re: Thank You
Postby CWoodONe » Mon Apr 28, 2008 7:41 pm
I can get the standalone to come up in Vista and work ok, but Cubase doesn't recognize the plugin at all on the PC. On the Mac, it's ok...
-- what version of Cubase are you on? Which OS?
one thing you might try in preferences is to turn off the autohide of the VST
plugins in the VST window, and maybe also turn off the setting to turn off
the plugin when there is no audio (even though I think EKeys is VST 2.x)
-- still playing around here...
CWoodONe
Postby 1nput0utput » Tue Apr 29, 2008 4:28 am
This may be caused by incompatible graphics hardware. What kind of graphics card is installed in your machine? I think MOTU's recent VIs (MSI, Ethno, MachFive 2, and EK) require certain OpenGL support from the graphics hardware that some older cards can't provide.
1nput0utput
Postby CWoodONe » Tue Apr 29, 2008 7:30 am
That's an interesting thought.. what happens when you click the
"effects" button? Does another window pop up?
CWoodONe
Cubase/EK
Postby drdrawbar » Tue Apr 29, 2008 7:32 pm
When i open the FX window, it pops up. but also only displays half of the GUI. I have recently found that minimizing the standalone and then maximizing it it displays correctly. Im using XP pro.
drdrawbar
Re: Cubase/EK
Postby CWoodONe » Tue Apr 29, 2008 8:13 pm
drdrawbar wrote:When i open the FX window, it pops up. but also only displays half of the GUI. I have recently found that minimizing the standalone and then maximizing it it displays correctly. Im using XP pro.
That definitely sounds like a coding bug.... I don't have XP so I can't test your exact situation... have you heard from other folks?
CWoodONe
Return to Electric Keys (Windows)
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Login Form
