It is currently Sun Feb 18, 2018 1:12 pm
Text Size
Motu Electric keys won't open in Logic Pro X.
Postby monogee » Sat Mar 26, 2016 2:34 pm
Motu Electric Keys is properly installed, updated, works as a stand alone, yet it does not appear as a choice in the instruments list for software instruments tracks in a song project.
Mac Pro (Early 2009), Processor 2x2.66GHZ Quad-Core Intel Xeon
OS X El Capitan 10.11.6
DP9 Ver. 9.5
monogee
Re: Motu Electric keys won't open in Logic Pro X.
Postby mikehalloran » Sat Mar 26, 2016 3:57 pm
Not enough information. What OS? Version of Electronic Keys? Logic Pro X version?
Did you install it in the default location?
Otherwise, best to start here:
http://www.motu.com/newsitems/motu-and-os-x-el-capitan
then here:
http://www.motu.com/products/software/e ... notes.html
July 2010 iMac 2.93G i7 Quad, OWC eSATA mod, 32G RAM, OS 10.13.1
828mkII FW; MOTU MTP/AV USB with Firmware 2.0.1; DP 9.5.1; IK-NI-Izotope-PSP-Garritan Antares, 32Lives, MachFive 3.2.1
LogicPro X 10.3.2, Finale 25.5, 2014.5, Encore 5.0.7, Notion 6, Overture 5, TwistedWave 1.18, DSP-Q 4.4, QuickTime Pro 7.6.6, SmartScore Pro X2 10.5.5, Toast 16
Test machine: G4-1K Dual Processor: OS 10.4.11 / OS 9.2.2; DP 5.13; Encore 5.05 & 4.5.5; Toast 9.07b, legacy apps
Postby monogee » Sat Mar 26, 2016 4:21 pm
I am running Motu Electric Keys 1.0.6. Mac OS X 10.11.4 and Logic Pro X 10.2.2. Motu Electric Keys is installed in the applications folder and the plugin is found in the components folder. It works fine in standalone mode but in Logic, it's not listed as a plugin.
DP9 Ver. 9.5
monogee
Postby bayswater » Sat Mar 26, 2016 5:36 pm
Is this a 32 bit versus 64 bit problem? Specifically, is EK running a 32 bit plugin while Logic X is looking for a 64 bit plugin?
2009 iMac 27" i7 16G, DP 8.07/9.02/9.5 & OS 10.12.6, Logic 10.3.2, Scarlett 18i8
2011 MBP 16G DP 9.5 & OS 10.12.6, Lexicon Alpha
Dual 2.0G G5 PCI 2G, DP 7.24 & OS 10.5.8, 2408 MKII, UAD-1
Postby monogee » Sat Mar 26, 2016 5:46 pm
Motu Electric Key is suppose to be able to work at 64Bits.
DP9 Ver. 9.5
monogee
Postby bayswater » Sat Mar 26, 2016 6:01 pm
Then, all I can suggest is you have a look in the Logic plugin manager and make sure it passed the AU validation scan and is "turned on". I have noticed Logic fails random AU plugins on the first scan and then passes them on the second scan.
Postby monogee » Sat Mar 26, 2016 6:14 pm
Well what do you know, the plugin finally appeared. :shock: Thank you everyone for your help. :D
DP9 Ver. 9.5
monogee
Postby mikehalloran » Sat Mar 26, 2016 7:34 pm
:band:
Return to Electric Keys (OSX)
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Login Form
