EK up on MOTU site!
EK up on MOTU site!
by nikki-k » Fri Apr 04, 2008 3:02 pm
Electric Keys is up there!
nikki
Mac Pro 1st gen 2.66, 4G ram; MBP 1st gen C2D; DP5.13; lava lamps and possessed stuffed animals...
nikki-k - Posts: 32
by monkey man » Fri Apr 18, 2008 5:33 am
Yikes!
Track 2 (Funky Board) is... George Duke.
Dang.
Why, oh why do I still choose to use hardware ROMplers?
Downloading track 3...
Dang.
8 Core 2.8GHz, 10G, 10.6.8, DP 7.24, WD Caviar Black
MOTU MIDI Express XTs, MOTU 24I/Os, Onyx 1620
MIDI Gear-Roland, Yamaha & Novation
Guitar & Bass - Line6, Music Man
Currently listening to TOTO, Steve Lukather, Dream Theater, George Duke and Japanese fusion: Tetsuo Sakurai & Dennis Chambers, Casiopea, Dimension, T-Square, Trix, Prism
monkey man - Posts: 11412
by monkey man » Sat Apr 19, 2008 2:28 am
To me, it's just more proof that MOTU's got a sufficiently large and diverse enough library already to at least be able to offer cut-down versions of MSI, Ethno, EK and MachV in DP, along with bread-and-butter offerings.
If MOTU had done this already, I'd have sold my hardware MIDI modules.
Call me naive (which I am, certainly), but I'm still holding out hope that said offerings or a comprehensive VI suite will arrive shortly.
I've just about had it (finally) with editing through tiny LCD screens - I've done my time (think WSSR etc) and no longer am inspired in any way by these beasts.
The cabling, routing of audio and MIDI, lack of sufficient outputs to mix sensibly, power consumption, extreme "uneditability" and blandness of these things have conspired to push me over the edge.
I really have had it.
OTOH, this EK VI from MOTU only serves to rub salt in my "I just know MOTU can and will deliver this at some point" wound, and convince me to hang out that bit longer in anticipation thereof.
Thank you Nikki for reminding us of this little gem.
by SixStringGeek » Tue Apr 22, 2008 1:31 am
monkey man wrote:I've just about had it (finally) with editing through tiny LCD screens - I've done my time (think WSSR etc) and no longer am inspired in any way by these beasts.
Hmmm. I dunno - I'm definitely all for moving to software instruments and retiring the hardware. But I've still got some hardware that makes noises I like that I can't find good software equivalents. Specifically, I've got a Korg DW 8000 with some timbres I just love and a Juno-106 that is easier to use than just about anything else (SLIDERS!). I keep looking for replacements though.
As to EK - I could definitely go for some more authentic rhodes sounds - but the rest of the collection seems to model instruments that strike me as dated sounding - I likely wouldn't use the real ones if I had them. Perfect emulations of cheezy instruments are still cheezy I think.
JambaLaya on MacBook for live performance.
DP 7.24 on MacPro Dual Quad 3GHz 24G Ram
Too many plugs to keep a list.
Wall full of guitars.
Sterling by MM Ray 34 Bass.
SixStringGeek - Posts: 1669
by monkey man » Tue Apr 22, 2008 4:14 am
Agreed on all fronts, Geekster.
I probably should have mentioned that the ability to load, tweak and save projects in a round-robin fashion is important to me.
Guess I'm just tired of reconfiguring projects, and I'm faced with the task of either doing this again now for the "new" working method I came up with of mixing hardware MIDI live (that's why I sold my big mixer), or taking that next step and moving entirely over to VIs.
My rig doesn't sound special in any way (or even good, IMHO), apart from my VL-70m and drum module.
At the very least, I'd hang on to the VL.
The hassle for me with this setup is mainly that archiving would have to involve rendering all MIDI as audio, otherwise hardware changes over time would mean impossible-to-replicate mix elements, and it was that rendering that I was hoping to avoid through the use of all those MOTU simultaneous analog ins.
I s'pose if my rig did sound great, I'd not be concerned as it'd be no burden to hang onto and continue to use.
The all-MOTU solution might be ideal for me given the fact that projects would (theoretically at least) always load as they sounded when saved.
3rd party hassles wouldn't be an issue, 'cause there wouldn't be any such party.
I agree that EK is an authentic-sounding cheese machine, but I've always wanted to explore the '70s funky/fusioney thing, so it could prove to be inspirational.
No matter - my point was simply that MOTU appears to have the resources and the smarts to put together a ripper of an all-in-one DAW.
I'm talking guitar amp sims, denoising, match-EQing, VIs... everything one would usually need.
IMHO, DP need only add a bunch of VIs and FX and it could validly claim the DAW high ground; this is what I've been hoping for for some years now, and after looking at that iLogical manual, I'm convinced there's not that much work to do.
All the functional elements of DP are in place, evolving and working well.
Adding utility plugs, FX and VIs should be relative no-brainers for these guys (and gals), IMHO.
Lots of assumptions and opinions here; I'm sorry about that Geekster.
Just thought I'd share my confusion with you.
Bottom line is I'm burned out and would settle for anything simple and convenient to operate, even if it meant compromising MIDI instrument quality somewhat.
Heck, a compromised VI palette would likely trounce my MIDI rig anyway.
Thanks for reading my previous post man, and sorry for the vent/dump.
by SixStringGeek » Tue Apr 22, 2008 5:40 pm
monkey man wrote:The hassle for me with this setup is mainly that archiving would have to involve rendering all MIDI as audio, otherwise hardware changes over time would mean impossible-to-replicate mix elements, and it was that rendering that I was hoping to avoid through the use of all those MOTU simultaneous analog ins.
Yes, I've concluded that the only sane thing to do is keep both the MIDI and render it as audio. Leaves options open while still retaining that sound I liked in the first place.
monkey man wrote:MOTU appears to have the resources and the smarts to put together a ripper of an all-in-one DAW.
I wouldn't expect MOTU to supply all the pieces. I think its too big of a job for one company. Anyhow, there's great stuff available by other parties. AmpliTube is really really good for guitar for instance.
But all the stuff is definitely available now to do monster cool recordings, you just have to pick your pieces and go.
Heck, for the bux - one of my best buys was the Korg Digital Legacy Collection (software M1 and WaveStation). Less than $200 and a LOT of useful sounds there.
by monkey man » Wed Apr 23, 2008 4:03 am
Yes, I've been watching the progress of KLC and KLCD over the years.
Stable from version 1.0 was impressive IMHO, Geekster.
You're right of course that all components are available now, but I don't yet trust 3rd party stuff to play nice with DP, at least not in the long term, hence my preference for an all-MOTU setup if possible.
Non-standardised preset handling and storage puts me off mixing (!) manufacturers too.
Heck if there weren't 200 odd unfinished songs I wouldn't be thinking this way so much, but as I've said, I'm so very tired of reconfiguring that I'll gladly take a quality hit for the convenience of the all-in-one solution.
I'm not sure it's too much to ask of MOTU.
Given that it's already given us MWEQ, pitch-correction, all those good stand-alone/cross-platform VIs and with the LA2A sim on its way, I don't think a match EQ, guitar amp and cab sims and the like are beyond it.
Given that the sims can be convolution based, their design and implementation need not be a huge task.
MOTU wouldn't have to provide the best of everything either - just its usual brand of HQ for the buck will do just fine, IMHO.
At any rate, I naively stand to attention, my gaze firmly fixed on MOTU's new-fangled website communication thingy for a clue or hint of what's to come like, well, a monkey who's gaze is firmly fixed on MOTU's new-fangled website communication thingy for a clue or hint of what's to come.
by CWoodONe » Thu Apr 24, 2008 4:01 am
noisetree wrote:Sounds great!!!
I‘m a DP,MX4,Ethno and Symphonic user.I think I‘m going to be
a happy Electric Keys user.
My best regards,
noisetree
How did you install it? I don't get any prompts to load the sample disks.
After the main install, nothing
Can't see a prefs either.....
DP 5.1, Ableton Live 6 Beta, Cubase, Absynth 3, BFD, Ivory, Cameleon, Tassman, Dimension Pro, Rapture, Kontakt 2, Minimoog V, Reason 3, Reaktor 5, Mac Pro, Trigger Finger, Axiom 25, Axiom 49
- CWoodONe
by carrythebanner » Thu Apr 24, 2008 5:55 am
CWoodONe wrote:noisetree wrote:Sounds great!!!
My best regards,
noisetree
I would guess you just drag the sounds over to your hard drive, same as MachFive. Check the manual.
- carrythebanner
by CWoodONe » Thu Apr 24, 2008 6:58 am
carrythebanner wrote:CWoodONe wrote:noisetree wrote:Sounds great!!!
My best regards,
noisetree
In the manual, you copy the files over to a hard drive, then install the app and it's supposed to find the samples... but it's not searching on my computer (Mac Pro quad core, Leopard)....
- CWoodONe
please somone help!
by ghostboy333 » Thu Dec 25, 2008 2:45 am
hi, my name is angie. i have recently purchased Motu's Electric Keys synth pack, and i was wondering if you could help me,
when i try to load the instalation disc onto my computer it always comes up with the same error message that sais :"Requires Vista or Windows XP to install"
now on the box it clearly states: compatible with Windows XP PRO 64 bit. my computer runs windows XP PRO 64 bit and i have gone from using the Program Compatability Wizard to
loading the ILOCK folder's 64 bit driver settings and still, NOTHING. i am soo disapointed becuase this was my christmass gift and i cant even use it.
if there is anything you could do to help i would be so greatfull.
-THANK YOU -angie
-THANK YOU -angie
- ghostboy333
• Page 1 of 1
Who is online
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
