It is currently Sat May 18, 2013 2:46 pm
Text Size
Ethno a no-show in DP 6
Postby tonester » Mon Sep 15, 2008 8:13 am
Hi:
New to the Mac side of things. Been a long time Sonar user. Just installed my DP6, and all of my instruments (Dimension Pro, EZ Drummer, MOTU's MSI) are recognized except Ethno. I am able to run it in standalone mode. If this is of any consequence, both my iLok licenses reside on one dongle.
Any clues?
Thanks...........
Anthony
Intel iMac
OSX Leopard
2.2Ghz
1G Ram
250G HD
tonester
Re: Ethno a no-show in DP 6
Postby stephentayler » Mon Sep 15, 2008 10:46 am
It's working here in DP 6.01 on a PPC G5 with Leopard 10.5.4.
Make sure that it is properly installed in the MAS plugins folder.
kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mac Pro 8 Core 2.8Ghz 16Gb RAM, MacBook Pro, 2Gb RAM, OSX 10.8.2, DP 8.01, PT9.06, Logic 9.1.8, MOTU Traveler, Ultralite Mk 3 Hybrid, MC MIx, MOTU VIs, Waves, Izotope Everything, Spectrasonics, SoundToys, Slate, Softube, NI Vintage Compressors, spl Surround Monitor Controller, spl Auditor Headphone amp, Genelec 1031A, 1029 5.1 system, Sontronics Mics, iPad etc..
stephentayler
Postby tonester » Mon Sep 15, 2008 1:36 pm
OK. I'll check that!
tonester
Postby tonester » Wed Sep 17, 2008 9:46 am
OK. I give up. I un, and re, installed Ethno. This time did a custom install with MAS, AU and RTAS checked (in case someday i use PT), but it still doesn't show up in DP 6.01's instrument menu. Where is the MAS plug-ins folder located? Maybe I can navigate to that to see if it's there?
tonester
Postby stephentayler » Wed Sep 17, 2008 10:00 am
2 possible locations
(your main HD)>Library>Audio>Plugins>MAS or Components
or
(your username)>Library>Audio>Plugins>MAS or Components
or try doing a search for
MOTU Ethno Instrument.bundle
MOTU Ethno Instrument.component
Make sure it is v1.01
best of luck!!
Stephen
stephentayler
Postby tonester » Wed Sep 17, 2008 10:22 am
I found the references to Ethno in the locations where you told me to look. I'm at version 1.00, though. Maybe that's the rub..........
I'll give that a shot.
tonester
Postby stephentayler » Wed Sep 17, 2008 10:45 am
Yes that is it....v1.01 added Universal binary support for Intel Mac.
Cheers
Stephen
stephentayler
Postby tonester » Wed Sep 17, 2008 11:22 am
stephentayler wrote:Yes that is it....v1.01 added Universal binary support for Intel Mac.
Cheers
Stephen
and that did the trick! Thank you........
tonester
Return to Ethno (OSX)
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
