Maybe a silly question..
Audio from my master keyboard (Roland RD-150) goes via first generation Traveler to an audio stereo channel in Logic Pro (10.3.2). There it is send to 'stereo out' To prevent double audio output (harsh!) I need to open the Cuemix FX 1.6 68717 app and set output analog 1-2 slider to '0' i.e. the bottom.
Is this standard procedure? I think the Traveler is operating now as a standalone decive AND as audio interface.
Best
John
preventing double audio output
Re: preventing double audio output
It sounds like you are monitoring the synth output through Logic and the Traveler CueMix app simultaneously. So, as you note, you can mute the CueMix channels to stop this. Or, if Logic allows it, you can turn off Input Monitoring in Logic and monitor via CueMix only.
CueMix should give you a lower latency result, as it is a hardware mixer not subject to computer-induced latency.
Unless you have to hear any effects in the Logic channel strips, you should be monitoring all your audio sources via Cuemix.
Thanks HCMarkus & bayswater! Think that ('it sounds like' is exactly the presumption I tried to explain in my Dutch-English. For the moment I kind of like the Logic EQ. Plus, the latency is so little it doesn't bother me.HCMarkus wrote:It sounds like you are monitoring the synth output through Logic and the Traveler CueMix app simultaneously. So, as you note, you can mute the CueMix channels to stop this. Or, if Logic allows it, you can turn off Input Monitoring in Logic and monitor via CueMix only.
CueMix should give you a lower latency result, as it is a hardware mixer not subject to computer-induced latency.bayswater wrote:Unless you have to hear any effects in the Logic channel strips, you should be monitoring all your audio sources via Cuemix.
Which means that whenever I start up the system I need to go to Cuemix.
If you change input sources and output destinations, you would have to go to Cuemix to set levels, etc, the same as would have to do with anything at the front end of your signal path. But otherwise, once you set Cuemix the way you want it, it will keep the settings, and there is no need to ever launch it. Note that if you have a few common Cuemix setups, you can save them as hardware presets. These can also be saved and loaded from the front panel (at least on they can on the MOTU units I have).johnthomaseindhoven wrote:Which means that whenever I start up the system I need to go to Cuemix.
