CueMix ULmk3 Sub
topaz
CueMix ULmk3 Sub
Post by topaz »
Hi Guys
I am struggling trying to get my sub working with the above setup.
Is it possible using OSX Sierra to route clean system audio out of outputs 1+2 and the same signal out of 3+4 but use CueMix to HPF to feed out to a SUB ?
I hope that is clear. is the issue that CueMix is only for routing external signals and not internal ?
Cheers
Matt
Re: CuneMix ULmk3 Sub
Most of us would not do it that way. Not sure what you mean by
What is your setup? What monitors and sub are you using?
There is more than one way to set things up. A little more info will help find the ideal solution.
topaz
Re: CueMix ULmk3 Sub
Post by topaz »
Cheers Mike
I have Mk3 FW, Mac Pro
Equator D5's and an old event S-100 Sub, it only has unbalanced rca (and way too noisy)
It also has a mono Input, what I wondered is if I can output a stereo pair to my monitors
with ie channel 3 also on the stereo out but filtered with Cue Mix.
so System/Daw audio out into 1+2 (filtered 53hz) the sub mono out 1+2 filtered above 54hz.
I hope that is more clear ?
Make it easy. The D5s don't have the low end for it to be a real issue unless you are cranking them really loud. The Event sub has a built in low pass at 120. I would run both as is. Careful placement of the sub will make it sound great. I never used a crossover with my D5s and my JBL subwoofer (the JBL has a switchable crossover — I ran mine at 120Hz).
Ted and I have had long talks about this over the years. He considers the ideal crossover is 80Hz for the D5. I don't disagree but 1/3 octave higher can still sound quite good and give you mixes you can trust. 53Hz is way too low.
I have an extremely noisy studio electrically due to 1960 non-grounded wiring and being in the middle of the silicon valley. Unbalanced in/out can be made to work by using balanced cables and terminating them mono. It's not theoretical in my room—the proper cables make a noticeable difference in noise levels that anyone can hear.
